Electrical What does a Roomba battery "reset" do?
  • Thread starter Thread starter Stephen Tashi
    Battery
A recommended solution for Roomba 500 series users experiencing battery issues is to reset the battery by holding down the "spot" and "dock" buttons. This reset may not completely discharge the battery but could alter settings in the robot's control system. The discussion highlights the memory effect associated with NiCad batteries, which can limit their recharge life if not fully discharged before recharging. This effect is caused by changes in crystalline structure within the battery, leading to increased impedance and reduced discharge capacity. To mitigate this issue, it is advisable to fully deplete the battery rather than charging it after short uses. For further information on battery characteristics, resources like Battery University are recommended.
Stephen Tashi
Education Advisor
TL;DR Summary
A suggested fix for a Roomba 500 series with a battery that won't hold a charge is to hold down the "spot" and "dock" buttons to "reset" the battery. What, physically, does this do?
A suggested fix for a Roomba 500 series with a battery that won't hold a charge is to hold down the "spot" and "dock" buttons to "reset" the battery. (e.g. ) What, physically, does this do?
Does it completely discharge the battery? Does it change some setting in the computer that controls the robot?
This is about 15% of the above-referenced page. Worth reading!
Originally, the terms memory effect or memory problem was coined to describe a cyclic memory problem where the NiCad battery would "remember" the amount of discharge for previous discharges and limit the recharge life of the battery. The problem is less prevalent with modern Ni-Cd batteries, which are designed to avoid cyclic memory issues.
The memory effect is caused by a change in crystalline formation from the desirable small size to a large size which occurs when a NiCad battery is recharged before it is fully discharged. The growth of large crystals increases the cell impedance and can eventually prevent the battery from discharging beyond that point...
Taking the above in to account, you are better off running down the battery instead of charging after every brief use.
The GO TO site for all things battery is https://batteryuniversity.com
https://batteryuniversity.com/article/bu-203-nickel-based-batteries
The above info, and enough more to put you to sleep, found with:
https://www.google.com/search?hl=en&q=nicd+battery+characteristics
Cheers,
Tom
Yes indeed. :smile:
There's someone else out there with a 500 series?? My people!
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Hot Threads
