What Does hp Represent in Power Units?
  • Thread starter Thread starter sybozo
    Means Unit
The unit "hp" stands for horsepower, which is a measure of power. One horsepower is equivalent to approximately 746 watts. Additionally, horsepower can be defined as 550 foot-pounds per second. The discussion highlights confusion around the unit's meaning and its conversion to watts. Understanding horsepower is essential for evaluating engine performance and power output.
sybozo
What does the unit "hp" means?
I admit that my physics sucks because it has been a long time since I heard the word "physics" but putting that aside, what does the unit "hp" represent/means? I don't remember learning that unit in school.
Eg. An engine develops 85hp
I'm guessing it's a Power unit and if it is, would it be like 85 hp = 8500 watts/J? or would it just be 85hp?
jtbell said:
hp = horsepower. Exactly how big it is depends on the horse. :biggrin:
http://en.wikipedia.org/wiki/Horsepower
Google Calculator gives a value of 1 hp = about 746 watts.
Thank you very much for replying! :smile:
1 horsepower = 550 ft-lb/sec.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
