What Experiment Demonstrates the Particle Behavior of Electrons?
bhsmith
I know the double slit experiment illustrates how an electron can be treated as a wave, but what experiment shows how an electron can be treated as a particle? i know of the photoelectric effect, but from what i can understand that seems to have more to do with photons acting as particles, not electrons.
If you perform the double-slit experiment but shoot one electron at a time in intervals you see illuminated points (particles, not waves). But if you perform this experiment for a period of time you realize that the individual points where the electron was illuminated creates an interference pattern as though each single electron's wavefunction interfered with itself, hence it is a wave and a particle simultaneously.
One should be thinking of no "particle" as a billiard ball type particle. Everything is a wave packet, which is why we describe them with wave functions and operators. When you fire a single electron you get a single point on the detector screen because there are no other wave packets to interfere with. When you fire many wave packets you get much interference. There is an interference pattern with Buckyballs.
The fact that one cannot detect an electron (or photon, for that matter) in two places at once.
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
