What factors determine the energy storage capacity of compressed gases?
In summary: Treat me tender now, I'm in early stage recovery from a, Von Neumann/Shannon induced coma:eek:The basic point I was making still stands: provided the gas is allowed to cool between compression and expansion, it doesn't have any more energy after compression and cooling than before compression. The heat flow comes after the work is already done.
  • #36
Stanley514 said:
So, why carbon nanotube springs have better energy density than steel springs?
The energy stored due to tensile stress per unit volume of solid is [itex]u = \frac{1}{2}Y \epsilon^2[/itex] in which Y is the Young modulus and [itex]\epsilon[/itex] is the strain.
Both factors, Y and maximum possible elastic [itex]\epsilon[/itex] are different for the two materials. The carbon-carbon covalent bonds exert more force per unit increase in separation of the atoms than the metallically bonded atoms in steel, leading to the nanotubes having a greater Young modulus than steel. Also, much larger strains can be suffered by the nanotubes than by steel before the material ceases to deform elastically. This is because the metallic bonding (pooled electrons) in the steel allows planes of atoms in crystals to slip over each other (promoted by the presence of dislocations) under moderate stress. This can't happen in the covalently bonded nanotubes, though they do break eventually under VERY large stress.
<h2>1. What is the relationship between pressure and energy storage capacity in compressed gases?</h2><p>The energy storage capacity of compressed gases is directly proportional to the pressure at which they are stored. This means that the higher the pressure, the more energy can be stored in the gas.</p><h2>2. How does temperature affect the energy storage capacity of compressed gases?</h2><p>Temperature plays a crucial role in determining the energy storage capacity of compressed gases. As temperature increases, the gas molecules gain more kinetic energy and take up more space, reducing the amount of gas that can be stored at a given pressure.</p><h2>3. What role does the type of gas play in its energy storage capacity?</h2><p>The type of gas being compressed also affects its energy storage capacity. Different gases have different molecular structures and properties, which can impact their ability to store energy at a given pressure and temperature.</p><h2>4. Can the container or vessel used to store compressed gases affect their energy storage capacity?</h2><p>Yes, the container or vessel used to store compressed gases can impact their energy storage capacity. The material, size, and shape of the container can affect the pressure and temperature at which the gas is stored, ultimately affecting its energy storage capacity.</p><h2>5. Are there any safety concerns related to the energy storage capacity of compressed gases?</h2><p>Yes, there are safety concerns related to the energy storage capacity of compressed gases. High pressures and temperatures can make these gases volatile and potentially hazardous if not handled properly. It is important to follow proper safety protocols when dealing with compressed gases.</p>
FAQ: What factors determine the energy storage capacity of compressed gases?
