B What forces act on a bar when you do pull-ups?
When performing pull-ups, the force exerted on the bar equals body weight when in equilibrium and not accelerating. If acceleration occurs, the force increases beyond body weight, with greater acceleration resulting in a higher force exerted. During the pull-up motion, the force fluctuates, becoming less than body weight as arms contract and increasing again during acceleration. This creates a periodic force pattern, roughly sinusoidal, with a baseline at body weight. Understanding these dynamics is crucial for analyzing the mechanics of pull-ups and similar exercises.
Lotto
TL;DR Summary
If you do pull-ups, a force acts on a bar when you move upwards. Is the force twice your weight or has it the same value?
I am not sure here, even though it is probably simple. If you just hang on the bar and don't move up, you act on the bar with a force equal to your weight. But when you want to do a pull-up, I would intuitively say that you act on the bar with a higher force.
But when I think about it I would say that when you move upward, you have to apply a force equal to your weight in order to make your body move (let's say we don't want to accelerate). So does that mean your body "levitates" and its weight doesn't count to the total force acting on the bar? The only force acting on it is only the force I am using to move my body?
Does it work the same way when doing push-ups? If I did it on a bathroom scale, would it show still the same value?
Do you reckon it matters how fast you pull yourself up? Is a really slow pull-up the same as a very fast pull-up?
Lotto said:
TL;DR Summary: If you do pull-ups, a force acts on a bar when you move upwards. Is the force twice your weight or has it the same value?
If you don't accelerate then you are in equilibrium and the force on the bar equals your weight. But if you do accelerate then the force ##F## that you exert is greater than your weight ##w##. The greater your acceleration the greater the value of ##F##.
And the force on the bar will be less than your weight as your arms get closer to full contraction until you stop and then as you accelerate down until you reach constant velocity again but down. So force as a function of time will be a periodic function, roughly sinusoidal, with a baseline at your weight.
Guys, I was trying to LEAD him to that, not spoon feed him the answer.
  • Love
Likes SammyS, russ_watters and hutchphd
Oops, sorry.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
