What Forces Conserve Energy and What Is the English Unit of Force?
  • Thread starter Thread starter Poy
    Forces Vectors
Forces are indeed vectors, characterized by both magnitude and direction, and their ability to conserve energy depends on the movement they induce. Work is not done, and energy remains unchanged if an object is not deformed or moves perpendicular to the force. However, energy changes occur when an object moves in the direction of the force or is deformed. The English unit of force is the pound, while the corresponding unit of mass is the slug, with the acceleration due to gravity being approximately 32 ft/s². Understanding these concepts is essential for grasping the relationship between force, energy, and motion.
Poy
Are all forces vectors? What forces do and don't conserve energy? What is the English unit of force? Its one of those little web search things, and some of those aren't so easy to find...
Hi, Poy,
Yes, forces are vectors, they are only completely described by giving them a length and a direction,
where we come to the question of energy:
it depends on the movement, displacement produced by the force.
If the body the forces acts on
1) is not deformed or moved --- no work is done, no change in energy.
2) moves perpendicular to the direction of the force --- no change in energy.
but
3) moves, but not perpendicular to the direction of the force, or is deformed against its inner "springs" --- there is some work done by the force and energy changes (at least, it transforms from potential to kinetic energy or temperature, depends whther the actor of the force belongs to the system).
Thomas
Yes, all forces are vectors. If you have a very artificial problem where you know everything will be in a straight line, you can set up your coordinate system so that the x-axis is along that line and ignore the other components, but the force really is a vector still. If a force depends only on position and not on such things as the speed with which an object is moving are conservative.
The English unit? You mean the one that the English don't use any more and only us silly Americans do? The pound. The corresponding unit of mass- the mass that on the surface of the Earth would weigh 32 pounds is called a "slug". (In the English system the acceleration due to gravity is about 32 ft/s<sup>2</sup> so the slug is a "unit" mass.) Unfortunately a lot of people also use "pound" when they really mean a "slug".
Lots of thank
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
