A What frequencies allow for the long wavelength limit in solid state physics?
Yu-Ting
In the "Introduction to Solid State Physics" by C. Kittel, there is a long wavelength limit in chapter 4 -Phonons I.
When Ka << 1 we can expand cos Ka ≡ 1 - ½ (Ka)2
the dispersion relation will become ω2 = (C/M) K2 a2
Does anyone know what frequencies can allow this long wavelength limit to hold?
I am not sure that there is a standard, since it likely depends on your application.
This is simply the Taylor approximation of the cosine function:
## \cos x = 1 - \frac12 x^2 + \frac{1}{24}x^4 - \frac{1}{720}x^6 ...##
Therefore, you can cut off the higher order terms whenever you feel they are small enough to be insignificant.
For example, when x = .1, your third term is less than .00001. Maybe this is small enough to disregard for your application. Maybe you need your error to be less than 10^-12. Then you should only apply the approximation when x is on the order of 10^-3.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
