What happens if I connect the electric cables in this way?
  • Thread starter Thread starter shaft
    Cables Electric
Connecting a secondary energy source with lower voltage to a light bulb powered by standard household current is theoretically possible but poses significant safety risks. It requires specialized equipment and knowledge, as improper connections can lead to dangerous situations, including electrical fires or electrocution. Regulations surrounding such setups are strict to prevent hazards during power outages. The safest approach is to use a dedicated system, like solar panels, designed for integrating alternative energy sources without risking safety. Attempting to connect alternate power sources to mains power without proper expertise is strongly discouraged.
shaft
If I have a light bulb that take energy by the normal current of the house but I want connect at the bulb an other part of energy from an other source of electricity but with an inferior Voltage.
This circuit will work or no.
How to connect the second source of energy to reduce the amount of energy of the principale source
There is no simple way of doing this safely, and you need a fair amount of equipment (it is of course possible, nearly every house with PV-cells on the roof will have the equipment)
The mere fact that you have to ask also means that you are not qualified do to it yourself.
Likes berkeman
it's just a theoretical question. I don't want kill myself .
I know that there should be something like an accumulator in the circuit between the second source of energy and the bulb . but I don't know if are necessary other parts
How to connect the second source of energy to reduce the amount of energy of the principle source
As f95toli says, this sort of thing is done with house-mounted photovoltaic power generation (merging that locally generated power with the utility's supply of AC Mains power). See these references for example, or use Google to find more...
http://energy.gov/energysaver/small-solar-electric-systems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&sqi=2&ved=0CDEQFjAAahUKEwiIluza7IPJAhUB32MKHRdjDPo&url=http://www.nrel.gov/docs/fy04osti/35297.pdf&usg=AFQjCNF6gg5QDmnMg54CWRHb7p1ChADUJg&bvm=bv.106923889,d.cGc
http://www.dummies.com/how-to/content/the-essentials-of-photovoltaic-solar-power-for-you.html
Likes billy_joule
The regulations for this are usually very strict. Imagine there is a power cut. You don't want your "second energy source" bursting into flames as it tries to power all the houses in the area. Nor do you want to accidentally electrocute the engineer sent out to fix the cause of the power cut.
Likes billy_joule and berkeman
The safe way to do it is to have a second light connected to your solar/wind alternative source.
Do not attempt to connect alternate power sources In parallel with the mains power yourself. That could result in injury or death.
Likes berkeman
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
