What happens in an heat flow apparatus when you reduce the length of t
Reducing the length of the second disk in a heat flow apparatus increases the heat transfer rate due to the relationship defined by Q = -λAΔT/d. As the length (d) decreases, either the temperature difference (ΔT) or the heat flow (Q) must change to maintain the equation. Consequently, the lower surface temperature of the second disk will rise above 30°C, leading to a higher temperature of the water exiting the system, which will be greater than 22°C. This indicates that both the heat transfer efficiency and the temperature of the cooling water increase with a shorter disk length. Overall, a shorter second disk enhances thermal performance in the apparatus.
352554
What happens in an heat flow apparatus when you reduce the length of the disk?
The apparatus is this
1st level: A resistor to produce heat
2nd level: A metal disk with known thermal conductivity coefficient
3rd level: A metal disk with an unknown thermal conductivity coefficient
4th level: Flow of water for cooling
The device if insulated so all the heat (ideally) flow from the resistor through the disks to the water.
The disks carry 2 thermocouples each to measure temp difference at given distance for each
You use the 1st disk to calculate the heat flow (known length, area, coefficient, temp difference)
The heat flow in the 2nd disk is the same as the one in the 1st
You calculate 2nd disk's coefficient using the same formula (known heat flow, length, area, temp difference)
My question is: What happens if the 2nd disk's length (the one with the unknown coefficient) is reduced? Since Q= - λ A ΔΤ / d and λ, Α are definite constants, either ΔΤ or Q with change. My guess is both. The out temp of the will rise (will be closer to the in temp) AND the heat flow will be more (the heat will transfer faster)
In order to be more clear
Say that the resistor gives off a temp 50C (constant)
In the original case: Let it be that the lower surface of the 2nd disk has a 30C temp and the running water's temp increases by 2C (from 20C to 22C) while touching that lower surface
1st level: Resistor at 50C
2nd level: 1st disk
3rd level: 2nd disk's upper surface
3rd level: 2nd disk's lower surface at 30C
4th level: Water comes in at steady 20C
4th level: Water takes heat from the lower surface of the 2nd disk
4th level: Water comes out at 22C
HEAT_FLOW_CASE_A
In the case that the 2nd disk has reduced length and everything else is the same (resistor 50C 1st disk length unchanged, water comming at 20C)
2nd level: 1st disk
3rd level: 2nd disk's lower surface at TEMP_A
4th level: Water comes out at TEMP_B
HEAT_FLOW_CASE_B
Questions
HEAT_FLOW_CASE_A < HEAT_FLOW_CASE_B
TEMP_A > 30C (disk's lower surface has increased temp)
TEMP_B > 22C (water coming out has increased temp)
Basically the heat will travel faster but also the lower surface of the 2nd disk will be hotter and that the water will remove more heat (also hotter)
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
