What Happens Inside BH Event Horizon?
In summary, the conversation discusses the concept of spaghettification and the singularity inside a black hole. The singularity is described as a moment in the future rather than a point in space, and the space inside the horizon is a finite but unbounded 3D space that shrinks until it becomes a point of zero size. The discussion also clarifies misunderstandings about the experience of someone inside a black hole, explaining that they would still experience tidal forces and stretching due to spacetime curvature, rather than the density of mass at a specific point in space. Additionally, the concept of time and gravity is not defined in the same
kochanskij
44
TL;DR Summary
What would a person inside a large non rotating black hole experience?
I have read about the spaghettification of objects due to tidal forces as they get close to the singularity. Gravity at your feet is stronger than at your head, so you get stretched and pulled apart. In this case, the singularity is a point in space.
But I also read about the time coordinate and the radial space coordinate becoming interchanged inside the event horizon. The singularity becomes an event in the future rather than a point in space. The space inside the horizon is a tiny self contained empty universe - a finite but unbounded 3D space, that shrinks until it becomes a point of zero size. This is the singularity, an event in time.
Which case is correct? Would you get stretched like spaghetti or crushed from all directions as the volume of space becomes less than your volume?
This is only true in one particular coordinate chart. It is not telling you anything useful about the actual spacetime geometry inside the horizon; it's only telling you about a particular property of that particular coordinate chart.
Not "becomes", "is". More precisely, it's a moment of time in the future--this moment is not a single event because it's not a single point, it's a spacelike line. Different objects can "hit" the singularity at different "places", just as different objects can pass through the same moment of time at different places.
This is not correct. What you are describing is the geometry of a contracting 3-sphere (such as the geometry of a closed universe contracting to a Big Crunch), and that is not what the geometry of spacetime inside the black hole is like. (It is what the geometry inside the collapsing object that originally formed the hole is like, but nobody who falls into the hole will ever see that geometry; the collapse will have finished before they could ever reach it.)
Yes, in some directions.
Not in all directions, but you will get crushed in some directions.
This is not why you get crushed in some directions. See above.
Likes PeroK, vanhees71 and Orodruin
PeterDonis said:
This is only true in one particular coordinate chart. It is not telling you anything useful about the actual spacetime geometry inside the horizon; it's only telling you about a particular property of that particular coordinate chart.Not "becomes", "is". More precisely, it's a moment of time in the future--this moment is not a single event because it's not a single point, it's a spacelike line. Different objects can "hit" the singularity at different "places", just as different objects can pass through the same moment of time at different places.This is not correct. What you are describing is the geometry of a contracting 3-sphere (such as the geometry of a closed universe contracting to a Big Crunch), and that is not what the geometry of spacetime inside the black hole is like. (It is what the geometry inside the collapsing object that originally formed the hole is like, but nobody who falls into the hole will ever see that geometry; the collapse will have finished before they could ever reach it.)Yes, in some directions.Not in all directions, but you will get crushed in some directions.This is not why you get crushed in some directions. See above.
Thank you for the clarification of my misunderstandings. But I'm still trying to picture what a person inside the BH would see and feel. Since the singularity is space like and in the future, he couldn't point towards it, right? Why would he experience tidal forces and stretching? Isn't that a result of a dense mass at a place in space? Why should gravity be stronger on his feet than his head? Don't his head and feet hit the singularity at the same time, just like your whole body reaches Monday at the same time?
No, he could not.
Because those are the result of spacetime curvature and spacetime curvature is non-zero. It is non-zero also outside of the horizon and also objects outside the horizon experience tidal forces. That is why we have … tides.
No. It is the result of spacetime curvature. Spacetime curvature depends on the geometry of spacetime, which depends both on the initial conditions as well as the distribution of matter in spacetime.
What do you mean by ”same time”? This is coordinate dependent.
Edit: It is true that the head and feet hit the singularity at spacelike separation.
Likes PeroK and vanhees71
I'm afraid that the event horizon is where trying to think intuitively about Einstein's gravity as if it were a mathematically more complex version of Newtonian gravity fails hard. You are thinking that tidal forces relate to how far you are from the source of gravity - this is no longer true inside the horizon. There's also no uniquely defined global notion of time any more (there is one in Schwarzschild spacetime outside the event horizon), and this turns out to mean that there's also no notion of gravitational potential, which means you can't think of gravity as a force - it's only spacetime curvature.
So yes, your head and feet will continue to attempt to separate. You can't attempt to characterise it in terms of different gravitational pull, though. Formally, it's characterised by geodesic deviation - the notion that "going straight ahead in spacetime" doesn’t mean quite the same direction to your head as it does to your toes. This induces some stress in your body to try to drag your toes and your head off their "natural" paths and on to the path of your center of mass. The effect grows without bound as you approach the singularity and eventually rips you apart.
Note that you can use the same reasoning above the horizon - it's just usually more convenient there to reason in more familiar terms.
Thank you for explaining this misunderstanding I had of gravity inside a black hole. So what would I see and feel while inside? I would be weightless in my free fall? I will feel increasing tidal forces no matter how I orient my body? I can't see or point to the singularity? Am I in a self contained tiny finite 3D universe? Can I see the outside universe or point toward outside? If another object falls across the horizon, where would I see it appear or come from?
(I'm not actually planning on jumping into a black hole!)
You would see light from the outside of the black hole.
Unless you accelerate using a rocket or similar. Just like outside the black hole.
What does this mean?
Yes.
Can you point to the future?
You would see it even before it passes the horizon. The horizon determines from where light cannot escape the black hole, it is not a separator preventing light from coming in.
Likes vanhees71
Space inside a black hole, for at least some definitions of space, is infinite in extent.
You can see outside, although I think it's aberrated into a tiny patch of sky behind you (if you fell in feet first and didn't reorient, 'behind you' means above your head, here).
As long as they drop in fairly soon after you (or if you have ridiculously large quantities of delta v) you can see the object outside before and after it falls in - it comes from the same patch of sky in my previous paragraph. If they wait too long you hit the singularity and die before seeing them fall in.
Curiously, at least in principle they will be able to see you after they fall in, however long they waited before following. In practice the light will rapidly red-shift into oblivion, so there's a practical time limit there too.
Likes vanhees71
Related to What Happens Inside BH Event Horizon?
1. What is a black hole event horizon?
The event horizon of a black hole is the point of no return, beyond which the gravitational pull is so strong that nothing, including light, can escape. It is the boundary that marks the point where the escape velocity exceeds the speed of light.
2. What happens to matter inside a black hole event horizon?
Once matter crosses the event horizon, it is pulled towards the center of the black hole, known as the singularity. As it gets closer to the singularity, it is stretched and compressed by the intense gravitational forces. Eventually, it is crushed to an infinitely small point, known as a singularity.
3. Can anything survive inside a black hole event horizon?
No, nothing can survive inside a black hole event horizon. The intense gravitational forces and extreme conditions would destroy any known form of matter.
4. What is the role of the event horizon in the formation of a black hole?
The event horizon is a critical component in the formation of a black hole. It is the point where the gravitational pull becomes so strong that it traps matter and prevents it from escaping. As more matter falls into the black hole, the event horizon expands, making the black hole larger and more powerful.
5. Can we observe what happens inside a black hole event horizon?
No, we cannot observe what happens inside a black hole event horizon. The intense gravitational forces and the absence of light make it impossible for any information to escape. Therefore, we can only study black holes indirectly through their effects on surrounding matter and light.
