What Happens to a Dead Galaxy's Mass?
  • B
  • Thread starter brand1130
  • Tags
    Mass
In summary: Stars just are slowly get ejected from the galaxies, in a process that's accelerated by the presence of a black hole.In summary, a dead galaxy will not lose its gravitational pull over time.
brand1130
TL;DR Summary
Does the gravitational pull of a dead galaxy diminish?
Summary: Does the gravitational pull of a dead galaxy diminish?
I have a question about dying galaxies. Most of the answers I've found thus far relate to them losing the ability to generate stars, or to general disbursement of mass caused by dark matter. This is not what I'm looking for. I am specifically curious about the mass of a dead galaxy. Here is my question: Does the matter in dead galaxies decay, and do dead galaxies lose their gravitational strength? Will the gravitational pull of a dead galaxy diminish over time as its matter converts to energy or other non-matter forms? Does it eventually vanish? Or does it become a bunch of cold rocks eternally floating through space? Thank you!
Astronomy news on Phys.org
No, why would it?
No, why would they?
No, why would it "convert" to anything? What force would cause that?
No
Yes
Likes ohwilleke, Bystander and Comeback City
Ahh, I was hoping for a more exciting answer than cold rocks. =(
Decay into pure energy, and then renew.
That would be pop-sci nonsense.
Likes ohwilleke and weirdoguy
Yes. When a star burns out to a white dwarf, only under 1 % of its mass is converted to energy and radiated away.
But why do galaxies lose the ability to generate new stars?
Typical mass of white dwarfs is under 0,6 solar masses - Procyon B is 0,60, and must have been more massive than Sun or Procyon A when on main sequence.
Therefore Sun-like stars must shed a large part of their mass into planetary nebulae in order to turn white dwarfs. Old galaxies where all more massive stars have decayed and Sun-like but older stars are right now burning out should contain lots of planetary nebulae.
Expansion speeds of planetary nebulae are slow. Much slower than galaxy escape speeds.
Gas shed by old stars in their old ages should get stuck and collect in galaxies.
Where is the gas shed by stars of old galaxies? Why is it not forming new stars?
New stars come from condensation of gas clouds. A dying galaxy presumably has run out of gas.
Likes ohwilleke
Perhaps not quite out, but with the gas having too low a density to accumulate enough to create stars/planets
Likes ohwilleke
Both energy and mass gravitate in proportion to E=Mc^2.
We have to define what we mean by "dead".
A galaxy can stop forming stars and still eject many stars. Black holes can still merge. A white dwarf or brown dwarf can still collide with a neutron star and flair into a Thorne-Zytkow object. 2 "dead" galaxies could collide and become lively.
Black holes have hawking radiation. If the theory is correct then a supermassive black hole will decay in around 1064 years. At the moment cosmic background radiation adds more mass to black holes than Hawking radiation takes away.
brand1130 said:
https://en.wikipedia.org/wiki/Hawking_radiation#Black_hole_evaporation
...Or does it become a bunch of cold rocks eternally floating through space?...
Not rocks in the long long run. Iron is the lowest energy state you can get through fusion. Falling into a black hole gives off a much larger amount of energy than nuclear fusion.
There are some ideas about proton decay. If proton decay exists then there will eventually be no rocks. 1036 years is a really long time. Is quite fast when we compare it to the 1064 years it takes for a supermassive black hole to decay by Hawking radiation.
All particles in a galaxy eventually either evaporate by 3 body interactions or fall into black hole. If a particle goes over the cosmological event horizon it will never come back. Light and gravity waves radiate out of a galaxy taking mass with them.
Yes, but energy travels at far over the escape speed of galaxy and promptly leaves it.
Eventually, old dead galaxies will probably evaporate, at least according to "The End of the Universe" <<link>>
This is not a peer reviewed paper, but I believe the author can be trusted. There is a list of the sources and references at the end of the article, though, for readers who want to find out more and who may be skeptical about the claims. I have to admit that I have not read the primary references at the end of the article.
It's not that the matter vanishes, is that stars just are slowly get ejected from the galaxies, in a process similar to how solids and liquids evaporate.
baez said:
In about 10^14 years, all normal star formation processes will have ceased, and the universe will have a population of stars consisting of about 55% white dwarfs, 45% brown dwarfs and a small number of neutron stars and black holes. Star formation will continue at a very slow rate due to collisions between brown and/or white dwarfs.
The black holes will suck up some of the other stars they encounter. This is especially true for the big black holes at the galactic centers, which power radio galaxies if they swallow stars at a sufficiently rapid rate. But most of the stars, as well as interstellar gas and dust, will eventually be hurled into intergalactic space. This happens to a star whenever it accidentally reaches escape velocity through its random encounters with other stars. It's a slow process, but computer simulations show that about 90% of the mass of the galaxies will eventually "boil off" this way — while the rest becomes a big black hole.
(It may seem odd that first the galaxies form by gravitational attraction of matter and then fall apart again by "boiling off", but the point is, intergalactic matter is less dense now than it was when galaxies first formed, thanks to the expansion of the universe. When the galaxies first formed, there was lots of gas around. Now the galaxies are essentially isolated — intergalactic space is almost a vacuum. And you can show in the really long run, any isolated system consisting of sufficiently many point particles interacting gravitationally — even an apparently "gravitationally bound" system — will "boil off" as individual particles randomly happen to acquire enough kinetic energy to reach escape velocity. Computer calculations already suggest that the solar system will fall apart this way, barring other interventions. With the galaxies it's even more certain to happen, since there are more particles involved, so things are more chaotic.)
There is a lot more in the whole article - and even more in the references it cites - but this snippet seems the most relevant
Likes mfb, stefan r, Klystron and 1 other person
Which would imply that over a really really long time (I'm practicing gross understatement here) the whole thing would boil away since Hawking Radiation will evaporate the BH.
Likes stefan r
Would you say that a galaxy that formed 10 billion years ago, still has 99%+ of its mass today?
Is the intergalactic medium escaping or falling in? If it is still falling in then the Milky Way has not finished forming yet.
The temperature of hot IGM gas is 105 to 107 K. Even at 107 it the average thermal velocity is not quite enough to escape the Milky Way from where the Sun is located. Gasses escape from atmospheres but that is because the Sun is adding energy and blowing out a solar wind. The intergalactic medium is hot because of particles falling out of the void. That makes me think it has to be falling in.
If we take 1036 watts as luminosity then a galaxy should be losing 1.1 x 1019 kg/s. If the galaxy is 2.2 x 1042 kg then it should radiate 1% of it's mass in 2 x 1021 seconds. 6.3 x 1013 years. There is no reason to think the galaxy's radiation is constant. Starbursts and active nuclei are brighter. 6,000 times as bright would not likely last over 10 billion years.
The Magellanic clouds have a star burst and are also dumping gas toward the MilkyWay. I do not know how much mass is in the Magellanic stream. Some galaxies in dense galaxy clusters have ram striping removing gas. That could take more than 1% of a galaxy's mass. That is probably not relevant to the original question.
It depends on the history of that galaxy. Did it collide with something? Did smaller galaxies fall into it? If it was just isolated in space: Probably yes.
Energy isn't an object. If you mean radiation, then yes.
Gravitational waves. Gravity waves are things like water surface waves.
Likes ohwilleke and stefan r
Look at conservation of energy aspect. Converting primordial gas into carbon and oxygen white dwarfs releases about 0,5...0,6 % as radiation, and is not completed in 10 Gyr.
Converting mass into neutron stars and black holes can release more.
It is.
My reasoning is:
in 10 Gyrs, a substantial fraction of original stellar mass should be shed from red giants into interstellar gas.
It should then be converted to new stars.
Yet old and yellow elliptical galaxies that don´ t seem to have either new stars or large masses of interstellar gas seem to be a common observation.
How, considering the mass of gas that must have been shed from the stars that burnt out?
Is there any efficient process at work to eject interstellar gas into intergalactic gas and prevent it from accumulating in the galaxy and forming new stars?
FAQ: What Happens to a Dead Galaxy's Mass?
What causes a galaxy to die?
There are a few reasons that a galaxy may "die." One possibility is that it has used up all of its gas and can no longer form new stars. Another possibility is that it has merged with another galaxy, disrupting its structure and preventing further star formation.
What happens to the stars in a dead galaxy?
The stars in a dead galaxy will continue to exist and orbit each other, but they will no longer be forming new stars. Over time, they will also eventually run out of fuel and fade away.
Does a dead galaxy still have a black hole?
Yes, even in a dead galaxy, the supermassive black hole at its center will still exist. However, without new stars and gas to feed it, it will no longer be actively growing.
How does the mass of a dead galaxy change?
The mass of a dead galaxy will stay relatively constant. While stars may die and be replaced by remnants such as white dwarfs and neutron stars, the overall mass of the galaxy will remain the same unless it undergoes a major merger with another galaxy.
Can a dead galaxy come back to life?
It is possible for a dead galaxy to experience a "rebirth" if it merges with another galaxy or if it interacts with a nearby galaxy that triggers new star formation. However, this is a rare occurrence and most dead galaxies will remain dormant for the rest of their existence.
