What happens to a pump's pressure gauge if you disconnect a hose line
When a hoseline is disconnected from a pump, the pressure gauge typically reflects the static or deadhead pressure of the pump rather than dropping to zero. This is because the gauge measures the pressure in the system, which can increase due to the removal of resistance. The flow rate may increase as a result of the disconnection, but this can lead to a decrease in pressure depending on the pump type and conditions. It's important to refer to manufacturer charts for specific pump performance under varying conditions. Overall, the dynamics of pressure and flow are influenced by the pump's characteristics and the system's configuration.
David43214
New user has been reminded not to try to use AI chatbots as references in the PF technical forums
TL;DR Summary
Would the pressure go up or down?
Imagine a firetruck with a hoseline attached to the pump. The pump is set to 800kpa with 100kpa loss due to friction in the 30m hoseline so you have 700kpa at the nozzle.
What would the pump's gauge read if you disconnected the hoseline?
I thought since there is no more resistance, the pressure gauge would show a much lower reading, maybe 0 because the pump's outlet is now at atmospheric pressure.
However, ChatGPT was telling me the gauge jumps to the static (deadhead) pressure of the pump.
I believe that you are correct: the gauge pressure would go down, while the waterflow would increase.
A chart for that particular pump should tell you what the manufacturer has recorded from the tests completed for different conditions.
Welcome to PF.
Please keep in mind that AI chatbots are not considered valid references in the technical PF forums. Thanks.
Likes sophiecentaur
Will the flow increase or decrease?
If the flow increases, does that mean the pressure falls?
Does it depend on the type of pump being used?
Does removal of the hose and nozzle restriction, connect the pump output with the gauge, directly to atmospheric pressure?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
12K
