I What happens to X-rays if they do not meet Bragg's law?
Bragg's law, expressed as 2d sin(θ) = mλ, dictates the conditions for diffraction in crystal planes. If an X-ray of slightly different energy strikes the crystal at the same angle θ, it will not produce the same diffraction pattern due to the change in wavelength. However, the electrons in the crystal continue to vibrate, allowing the possibility of diffraction at different angles for the new wavelength. The energy from the X-ray does not spread evenly in 4π but can interact with other crystal planes. Each wavelength generates its own distinct diffraction pattern, which can overlap on a detection screen.
gaiussheh
Bragg's law states that it must meet ##2d\sin[\theta]=m\lambda## for diffraction to happen. I just wonder, if you have an x-ray of slightly different energy that hits the crystal plane at the same angle ##\theta##, what would happen? It certainly can't form the same diffraction pattern at the same angle ##\theta##, but as the electrons in the crystal still vibrate, the x-ray still goes somewhere. Can they find another plane so that the diffraction happens at another angle? Or is the energy spread out evenly in ##4\pi##?
Likes Philip Koeck
For any EM radiation, each wavelength forms its own diffraction pattern independently and these are superimposed on a screen.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
