B What happens when 2 beams of light interact?
  • B
  • Thread starter Thread starter rgtr
    Beams Light
rgtr
TL;DR Summary
I was reading sometimes nothing happens when 2 beams of light interact but other times it can cause light to turn into other particles. What particles does the 2 light beams turn into?
I realize turn into probably isn't the correct term.
Also I know gravity can bend light but can gravity cause light to turn into other particles?
I am layman so can someone explain this in layman's term? Also I am not even sure the quantum section is the correct section.
rgtr said:
Summary:: I was reading sometimes nothing happens when 2 beams of light interact but other times it can cause light to turn into other particles. What particles does the 2 light beams turn into?
Generally, 2 beams of light do not interact. When they do, they do not create particles other than light.
And gravity does not turn light into other particles. It is not clear that gravity is a quantum force, which would be necessary for that to ever be a consideration.
As a side note, it would be helpful to mention where you read that light "turns into other particles" so we would have some context. There are situations, for example, where energetic photons can interact with other particles yielding a variety of results.
I assume no one knows what gravity is in quantum mechanics. Is my assumption correct?
But assuming gravity is quantum force how does this change the particle of light into other particles?
Also when do 2 light beams interact and what are the results? What is an energetic photon vs a photon?
I think you can get electron-positron pair production for very high intensity and high energy beams.
As far as I know, it has not been observed directly yet, but in leading order QED perturbation theory of order ##\alpha^2## two photons can annihilate to an electron-positron pair. It's the time-reversed process of electron-positron annihilation to two photons.
At higher orders you can also have the elastic scattering of two photons (order ##\alpha^4##). It's a set of one-loop diagrams with four electron-positron lines running around.
Likes DrChinese and Dale
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
