I What happens when an explosion occurs on the surface of the moon?
  • I
  • Thread starter Thread starter TitaniumVCarbon
    Explosion
An explosion on the moon results in unique behavior of expanding gases due to the lack of atmosphere and lower gravity. Slower explosions create ground-hugging flows similar to pyroclastic surges on Earth, while faster explosions generate high-speed gas that behaves like wind, potentially deflecting around obstacles. The intensity of the wind diminishes over time, and the explosion can propel debris outward, creating distinct material flows. Historical examples, such as the Apollo 12 mission, illustrate the effects of even minor explosions on lunar surfaces. Understanding these dynamics is crucial for assessing the impact of potential lunar explosions.
TitaniumVCarbon
TL;DR Summary
Some aspects I assume a lunar surface explosion would have that I havent found any mention of. Do these aspects exist? If so, why havent they been mentioned?
In an explosion in space, material is heated and expands. On the surface of Earth, it doesnt get too far, instead transferring its energy into shockwaves and tremors. But on the surface of the moon, if I'm right:
- Explosions with slower initial speeds (of the expanding material that makes up the blast, which is equivalent to the heat at the centre of the blast) have expanding flows of hot gas that, because they dont move fast enough to be more or less unaffected by lunar gravity, are groundhugging, and would be like a pyroclastic surge on Earth.
-With higher speed explosions, the hot gas, pushed out by the explosion, would be travelling faster and would be like 'wind'. It could be deflected by obstacles (asumming those remained intact, but the hot gas, if still hot, would have a tendency to expand and so, as it moved past an obstacle would expand to fill the void created by said obstacle. If it has cooled down to having little or no heat, you might be able to escape the wind by hiding behind some sort of barrier.). The speed of the explosion, and thus 'wind' depends on the initial temperature of the blast.
-In both cases, the wind would be strongest as it hit your location and, from the perspective of any specific location, would weaken as time passed. Also, the wind would throw up material on its own, and this material could travel independently (without being slowed down by air) and make up its own flow of material. And the explosion itself could throw out bits and pieces of the bomb, asteroid, or surrounding material and send it hurling outwards, sandblasting the surrounding area, and perhaps creating its own distinct flow of material as well. Not that it has to be groundhugging like a pyroclastic surge. (This happened to Surveyor 3 when Apollo 12's exhaust shot out particles everywhere. The probe was 180m away and Apollo 12's engine was a dimunitive one compared to some commonly used ones, so imagine what magnitude this would be if an actual surface explosion happened).
Didnt tell me much, except apparently the pressure peak isnt right when the blast qave hits and decreasing thereafter. The ppressure peak is a few microseconds after the detonation wave hits.
I havent read the second text yet (the one about lunar dust). I didnt spot the link until now.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
