What Happens When H2 and O2 Particles Interact Without a Catalyst?
  • Thread starter Thread starter Quadruple Bypass
    Reaction
In a closed environment with hydrogen (H2) on one side and oxygen (O2) on the other, removing the partition allows the gases to mix. However, for a reaction to occur and form water (H2O), activation energy is necessary. This energy can be provided by a spark or other catalysts to initiate the reaction. The discussion highlights the importance of activation energy in chemical reactions, particularly in the formation of water from hydrogen and oxygen.
Quadruple Bypass
i studied chemistry about 6 years ago and don't remember much :smile:
I have a question though, let's say that you have a room and you put a partition in the middle of it. On one side is H2 and on the other is O2. Now if you remove this partition, do the H2 and O2 particles start to react with each other to form water or do you have to have some sort of catalyst to start this reaction (like a spark)?
Chemistry news on Phys.org
Errr, just got my answer, never mind this thread!
Activation energy being the keyphrase...
methods
Can you please tell the answer?
Do you know activation energy is?
methods
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
