B What Happens When The Applied Force Equals the Static Friction Force?
When the applied force exceeds the maximum static friction force, the object begins to move with constant acceleration. Initially, the applied force and static friction balance each other, preventing motion. Once the applied force surpasses static friction, the object accelerates until it reaches a constant velocity, where the applied force equals kinetic friction. The difference between static and kinetic friction determines the acceleration during this transition. Thus, the key point is that acceleration occurs only when the applied force exceeds static friction.
vibha_ganji
In my teacher’s notes, it said that when the applied force on an object equals the maximum static frictional force, the object begins to move at constant velocity. My question is if both the applied force and the frictional force cancel as they are equal in magnitude, what force accelerates the object from zero velocity to its constant velocity?
Usually kinetic friction constant is smaller than static friction constant.
Applied force which equals the maximum static frictional force - the kinetic frictional source
would accelerate the body.
After it starts moving if applied force is lessened to equal the kinetic frictional force, it would move with constant speed.
Likes Lnewqban and tech99
This doesn't sound right. It should be:
... when the applied force on an object exceeds the maximum static frictional force, the object begins to move with constant acceleration.
Note that static friction is usually greater than kinetic friction, so that you get a significant acceleration depending on how large this difference is. If the force is constant, then there is theoretically a minimum acceleration of ##\frac{f_s - f_k]{m}##, where ##f_k## is the kinetic friction, ##f_s## the static friction and ##m## the mass of the object. We assume that the applied force is approximately ##f_s## but just a tiny bit more.
Likes Lnewqban and weirdoguy
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
