What Happens When You Integrate the Square of the Delta Function Over All Space?
  • Thread starter Thread starter bishshoy007
    Impulse Integrate
bishshoy007
\int \delta(t)^{2} dt from -infinity to +infinty
\int^{\infty}_{-\infty}\delta(t)dt = 1
\int uv dt = u\int v dt - \int u^{'}(t)\int v dt dt
\int^{b}_{a} f(x) dx = F(b) - F(a)
\delta(-\infty) = \delta(\infty) = 0
\int \delta(t) . \delta(t) dt = \delta(t)\int \delta(t) dt - \int \frac{d \delta(t)}{dt} . \int \delta(t) dt dt = \delta(t).1 - \int \frac{d \delta(t)}{dt}dt = \delta(t) - \delta(t) = 0
The integral of delta(x)^2 is not defined, it's infinite. Is that really the problem you were given?
Thank you for replying.
\delta(t) is an energy signal. I'm trying to find out the energy of the signal.
I wonder why the integral came out to be zero. I want some expert advice, whether I have done the integral correctly or not, or if there is some other explanations.
anybody please answer to my problem.
why the integral turns out to be zero.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
