sophiecentaur
- 30,131
- 7,398
MikeyW said:Something I am unsure about. Does energy ever get transferred between frequencies?
eg. I pluck a string in a specific way to only excite two frequencies:
frequency #1 has amplitude 2, and frequency = 2.12934*fundamental frequency
frequency #2 has amplitude 1, and the fundamental frequency.
We know the higher amplitude component of the wave will be damped much faster, but it begins with much more energy, so is there any mechanism to transfer that energy to other frequency components? Neglecting 2nd order effects of the nodes themselves being displaced (neck, bridge, etc.) and then re-oscillating the string.
I think the problem is that you are associating the plucking of the string with actual frequencies. All you are doing when plucking the string is to displace it, physically (no frequencies or wavelengths involved yet). You then let it go with potential energy that gradually transfers and shares with kinetic energy. The way that this sharing is achieved is up to the system. The oscillations that will take place are then a function of the system. This is very like the time domain (or impulse) response of a electrical filter. What you see there is the response of the system to an infinitely short burst of energy, to which you can't give a meaningful description of spectral content. For a resonant circuit, this will be a decaying sine wave of a frequency given by the LC combination in the circuit.
You could, however, discuss what happens if you try to excite a string with a continuous wave of a single frequency (say with a vibrator, loosely coupled to the string). The amplitude at which it will resonate is a maximum at the string's fundamental, of whichever overtone your tone is at. This, as we have discussed, is because the waves progressive waves on the string happen to interfere consistently along its length, producing nodes and antinodes. Slightly off frequency, there will also be some response and the response will depend on the damping factor (or Q) of the resonator. If you remove the excitation, there is no way that the frequency can suddenly shift because that would violate all sorts of boundary conditions***. All that will happen is that the natural losses in the system will cause the tone to dissipate - once you have removed the off-frequency excitation (which forces some some pattern on the waves on the string) the wavelength of the forced oscillation will not correspond to the length of the string so you will expect to have waves moving from end to end and back again as they gradually dissipate. The rate of decay should be similar to the decay of a natural resonation, I think, because the resistive mechanism will be the same.
*** To get any frequency shift, you need a non-linearity in the system. All the above (and the rest of the thread, mainly) assumes an ideal, linear system.
