only1god
- 43
What would be the consequences of such thing? How it will affect physics theories and the world?
Why and How?Dale said:So a future experiment that showed it to be wrong would be a very small effect.
Current limits are ##10^{-15}##. See https://en.m.wikipedia.org/wiki/MICROSCOPEonly1god said:Why and How?
What did you meant by very small effect? effect in whatDale said:Current limits are ##10^{-15}##. See https://en.m.wikipedia.org/wiki/MICROSCOPE
The experiment measured the acceleration of different objects in free fall. As predicted by the equivalence principle, those accelerations were equal to each other to within 0.0000000000001 %. That is a small effect.only1god said:What did you meant by very small effect? effect in what
That's the weak equivalence principle which is true and we can experiment it ourselves. I'm talking about Einstein's equivalence principle which says you cannot distinguish an accelerated rocket going at 1G for example from the Earth gravitational field. My question was about what if some experiment prove that what Einstein said was wrong, and how will that affect modern physics.Dale said:The experiment measured the acceleration of different objects in free fall. As predicted by the equivalence principle, those accelerations were equal to each other to within 0.0000000000001 %. That is a small effect.
Well, you say you are talking about the Einstein equivalence principle, but what you actually describe here is the weak equivalence principle.only1god said:I'm talking about Einstein's equivalence principle which says you cannot distinguish an accelerated rocket going at 1G for example from the Earth gravitational field.
No, it's not. Weak equivalence principle is about objects with different mass falling at the same time but it don't have the "challenge" that Einstein put.Dale said:Well, you say you are talking about the Einstein equivalence principle, but what you actually describe here is the weak equivalence principle.
However, if you are interested in the Einstein equivalence principle, it has been tested down to ##10^{-7}##. Not as small as the weak equivalence principle, but still pretty small. Any future experiment that showed a violation in the Einstein equivalence principle would have to fit within that small limit.
Do you mean the distance or size with that limit?Dale said:Well, you say you are talking about the Einstein equivalence principle, but what you actually describe here is the weak equivalence principle.
You probably should read the Wikipedia entry for the equivalence principle. You have a misunderstanding about the different equivalence principles.only1god said:No, it's not. Weak equivalence principle is about objects with different mass falling at the same time but it don't have the "challenge" that Einstein put.
No, it is an accuracy limit. The predictions of the Einstein equivalence principle have been verified accurate to within 0.00001 %. That is the standard way to report such things, as a fractional error. So a limit of ##10^{-7}## means that if the Equivalence principle predicted some value is ##1## then it was actually measured to be ##1\pm 0.0000001##only1god said:Do you mean the distance or size with that limit?
But isn't the weak equivalence firstly supposed to be quote by galileo?Dale said:One specific statement of the weak equivalence principle is “The local effects of motion in a curved spacetime (gravitation) are indistinguishable from those of an accelerated observer in flat spacetime”. This is what you mistakenly described as the Einstein equivalence principle in post 7.
It means that any violation of the EP must be very small (or we would have already seen it). If we find such a small violation then that establishes a “domain of applicability” for general relativity. We can still use GR within that domain, including all of the experimental domains tested to date.only1god said:I still don't understand the limit because, if Einsten EP is proven to be wrong, What that limit has to do with it?
There is no hard cut off, but I consider ##10^{-7}## and ##10^{-15}## to be small.only1god said:But what small means?
It doesn’t matter since the violations cannot be big. They must be less than ##10^{-7}## which is already small. So any violations must be smaller than small.only1god said:What are the consequences of a big violation?
I think the trouble you are experiencing is that we already know it is correct, down to a small fraction of measurement.only1god said:But what small means? and What for example a big violation would be? and What are the consequences of a big violation?
The mostly likely thing that would mean is that they misunderstand the EP.only1god said:For example, if an observer inside the box find a way to distinguish, Would that mean small or big violation of the EP?
Maybe some experiment or idea are still without being tested?DaveC426913 said:I think the trouble you are experiencing is that we already know it is correct, down to a small fraction of measurement.
It makes no sense for you to speculate that observations and measurements we have already confirmed are now, suddenly and inexplicably wrong.
Sure. But that experiment will not show an error greater than those already cited in this thread. i.e. best it can do is show an error of, say, one part in ten million.only1god said:Maybe some experiment or idea are still without being tested?
Why it's impossible? I don't think all ideas or experiments were tested...DaveC426913 said:The mostly likely thing that would mean is that they misunderstand the EP.
You are having trouble understanding what work has gone before.only1god said:Why it's impossible? I don't think all ideas or experiments were tested...
One thing will make me understand if you respond it as clear as it possible. Imagine some idea that prove us indeed we can distinguish between an accelerated frame and a gravitational field, some idea that was not discovered nor tested before. The question here is, leaving apart that limit, Will that mean if the idea is true that Einstein's EP is wrong?DaveC426913 said:You are having trouble understanding what work has gone before.
We already know the EP holds down to one part in millions.
I'm sorry to say that what it will surely mean is that the idea has not taken into consideration the conditions of principle of equivalence.only1god said:Will that mean if the idea is true that Einstein's EP is wrong?
It would mean that general relativity fails in some case, and that, as a result, there would be no known theory of gravity consistent with experiment. Some unknown theory would be needed that duplicates all the great many validated predictions of general relativity, while also explaining this anomalous experiment.only1god said:One thing will make me understand if you respond it as clear as it possible. Imagine some idea that prove us indeed we can distinguish between an accelerated frame and a gravitational field, some idea that was not discovered nor tested before. The question here is, leaving apart that limit, Will that mean if the idea is true that Einstein's EP is wrong?
Local means i cannot go out of the box?DaveC426913 said:I'm sorry to say that what it will mean is that the idea has not taken into consideration the conditions of principle of equivalence.
For example, when I was young, I too thought I had figured out how to tell the difference between gravity and acceleration in a closed room. Obviously, gravity has tides, whereas acceleration does not!
Except the EP is specifically limited to local conditions. Local, in this case, means I can't check the force at the two ends of my room. Which means I cannot measure differences within the room; I can only take my measurements at a single point. And that leaves me with no way to test for tides.
See?
It doesn't mean your idea is wrong; it simply means - sorry if this seems glib, but - if you want to try thinking outside the box, you first need to spend enough time studying so you learn where the box is.
Correct.only1god said:Local means i cannot go out of the box?
Local means limited in spatial extent such that tidal gravity is undetectable, and also limited in duration, because you can trade duration for size. That is, pick an arbitrarily small box, if you make some observations over a long enough time, they can detect tidal gravity. Omitting this fact is the error in a whole series of false claims by Ohannian about the equivalence principle. And, of course you cannot go or look outside the box.only1god said:Local means i cannot go out of the box?
Yah. This.PAllen said:Local means limited in spatial extent such that tidal gravity is undetectable...
Thanks, now i understand. Einstein put a lot of limits lol.DaveC426913 said:Correct.
More than that, you can't even take measurements at different places inside the box.
A lot of scientists would show up at your door.only1god said:What if someone indeed find an idea that is local, and that idea turns out to be right? What would be the impacts?
I don’t think this is required, as long as the measurements are close in both location and timeDaveC426913 said:Correct.
(To clarify: It's not that you can't take measurements at different places; it's that the EP is not meant to apply in that condition.)
See post #27only1god said:Thanks, now i understand. Einstein put a lot of limits lol.
