What if we get the answer before anyone.
  • Thread starter Thread starter Sumedh
When a user resolves their own issue in a forum thread before receiving any responses, it is recommended to post an update indicating that the problem has been solved. This helps prevent others from wasting time on the thread. Additionally, editing the original post (OP) to highlight the solution is beneficial for visibility. The discussion humorously touches on the idea of seeking advice from various figures, like priests and politicians, to validate the solution, but ultimately emphasizes that personal resolution is key to truly solving a problem.
Sumedh
If I started a new thread (having a problem)
And it gets solved by myself , before anyone posts in it,
So what should be done at this time?
Should i post that the problem or difficulty is solved?
Yes, post that you have solved it. Even better: edit the OP and put at the top that you have solved it. That way people will see this and won't waste their time :smile:
First consult a priest, then a philosopher, and finally a politician to insure you have actually solved the problem.
The first will tell you it's impossible, as only God can truly solve problems. The second will tell you the problem is solved as soon as you change your view of the world. The third will assure you they've either already solved the problem so you should vote for them, they will soon solve the problem so you should vote for them, and that the problem was solved by their opponent so please don't vote for the other guy.
In reality, you will always have the problem until you solve it yourself.
"In 2013, after a series of hospitalizations due to magnets, New Zealand government officials permanently banned the sale of those made from neodymium-iron-boron (NIB)." https://www.sciencealert.com/new-zealand-teen-loses-part-of-his-bowel-after-swallowing-nearly-200-magnets "A 13-year-old boy in New Zealand has had part of his bowel surgically removed after he ingested nearly 200 high-powered magnets. (2025)" OK, this teen was a fool, but it is not always a teen, it is not always...
Thread 'RIP Chen Ning Yang (1922-2025)'
https://en.wikipedia.org/wiki/Yang_Chen-Ning ( photo from http://insti.physics.sunysb.edu/~yang/ ) https://www.nytimes.com/2025/10/18/science/chen-ning-yang-dead.html https://www.bbc.com/news/articles/cdxrzzk02plo https://www.cpr.cuhk.edu.hk/en/press/mourning-professor-yang-chen-ning/ https://www.stonybrook.edu/commcms/physics/about/awards_and_prizes/_nobel_and_breakthrough_prizes/_profiles/yangc https://www.stonybrook.edu/commcms/physics/people/_profiles/yangc...
