What is a feed through term in block diagram?
In summary, a feed through term in block diagram refers to an input signal that passes through a block without being affected by its internal operations. It is different from other terms as it does not undergo any transformations and is important to identify for understanding and simplifying the system. Examples include gain, integrator, and summing blocks, and it can be eliminated by using different blocks or rearranging them.
gaus12777
I`m reading some paper about control engeneering.
But I don`t know what is feed through term exactly. Is it a connection between some point in one circuit?
You should post a copy of the sentence that includes that term to give us some basis for its context in the sentence.
Related to What is a feed through term in block diagram?
A feed through term in block diagram refers to an input signal that directly passes through a block without being affected by the block's internal operations. It is often denoted by a straight line connecting the input and output of a block.
How is a feed through term different from other terms in a block diagram?
A feed through term is different from other terms in a block diagram because it does not go through any mathematical operations or transformations within the block. It simply passes through the block and appears at the output unchanged.
Why is it important to identify feed through terms in a block diagram?
Identifying feed through terms in a block diagram is important because it helps in understanding the overall function of the system. It also allows for the simplification of the block diagram, making it easier to analyze and design the system.
What are some examples of blocks with feed through terms?
Some examples of blocks with feed through terms include gain blocks, integrator blocks, and summing blocks. These blocks do not have internal operations and simply pass the input signal to the output.
Can a feed through term be eliminated from a block diagram?
Yes, a feed through term can be eliminated from a block diagram by using a different block or by rearranging the blocks. This can help in simplifying the block diagram and reducing unnecessary calculations in the system.
  • Electrical Engineering
  • Mechanical Engineering
