I What is a "temperature distribution" in a stellar photosphere?
A temperature distribution in a stellar photosphere describes how temperature varies within the Sun's outer layer, with the effective temperature being approximately 5,600ºC. The opacity of solar gas affects visibility, as it can be transparent or opaque, influencing how we perceive light from different angles. Observations show that light intensity decreases towards the edges of the solar disk, a phenomenon known as darkening in the limbus. The temperature gradient indicates that the photosphere's temperature decreases from about 5780 K at its base to 4200 K at the lower chromosphere. This gradient is mathematically represented by the temperature distribution, illustrating the relationship between temperature and radiation characteristics.
AlphaCrucis
TL;DR Summary
Explain what we mean by the term "temperature distribution" in the context of stellar photospheres.
What is a "temperature distribution" in the context of a stellar photosphere and How is the temperature distribution related to the effective temperature?
Astronomy news on Phys.org
The effective temperature of the Sun's surface is about 5,600ºC. This data is important because the characteristics of the radiation emitted by a body are a function of its surface temperature.
A gas can be transparent, partially transparent, or opaque. Opacity is a measure of the transparency of a gas per unit length. If the opacity of a gas is very large, we cannot see very far through it.
When we look at the Sun, we see through the solar gas until the optical depth is very great and it becomes opaque. The base of the photosphere is defined as the level to which we can see directly at the center of the solar disk.
When we take pictures of the Sun, we find that the intensity of the light varies from the center of the disk towards the limbus. The regions near the edge are darker than the regions near the center, this phenomenon is called darkening in the limbus.
When we look at the center of the solar disk, that is, in the perpendicular direction, we can see up to the level that we have defined as the base of the photosphere, the deeper the solar gas is opaque. The radiation received therefore corresponds to this level, which compared to that of the black body corresponds to a temperature of 5780 K. When we observe at a point other than the center of the disk, the observation direction is no longer perpendicular, as we go towards the limbus we observe almost tangentially to disk. The gas becomes opaque at a level located above the base of the photosphere, at the same depth because it is an oblique line we see a higher level than when observing perpendicularly Solar gas when we observe near the limbus emits less radiation than near the center and comparing with a black body it corresponds to a lower temperature. Consequently we can deduce that the temperature of the photosphere increases as the radius decreases, in Physics it is said that there is a negative temperature gradient. In fact, the temperature decreases from the base of the photosphere (5780 K) to about 500 km above where its value is 4200 K, this limit corresponds to the lowest part of the chromosphere.
The temperature distribution is the mathematical representation of that gradient.
Sources: in Spanish
http://www.juntadeandalucia.es/aver...rio/250/289/html/antares/modulo4/m4_u103.html
http://edii.uclm.es/~arodenas/Solar...peratura efectiva de la,de la superficie del% 20 itself.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
