I What is meant by 'affine' model in physical sciences?
  • I
  • Thread starter Thread starter feynman1
    Model Physical
The term "affine model" in physical sciences appears to be a conflation of "affine transform" and an ideal model. An affine transform is a mathematical operation that preserves parallel lines and is used to map an ideal model to a real-world example. There is no established concept of an "affine model" as a standalone term in the literature. Instead, it may refer to a model that has undergone an affine transformation. The discussion highlights the distinction between the ideal model and the transformation process rather than establishing a unique category of models.
feynman1
What's meant by 'affine' model in physical sciences? I guess it's related to some ideal or benchmark model?
A ideal model is compared with a real example.
The connection or mapping between the two is an 'affine transform'.
An affine transform preserves parallel lines.
I guess the model of the ideal could be called an 'affine model'.
https://en.wikipedia.org/wiki/Affine_transformation
affine transform has nothing to do with affine model?
There seems to be no such thing as an "affine model".
"Affine model" appears to be a conflation of the terms "affine" transform and the transformed ideal "model". That might be used to refer to a model that is subjected to an affine transform.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
