I What is Nonlinear Least Squares in Regression Analysis?
Nonlinear least squares is a technique used in regression analysis to estimate coefficients for models that do not follow a linear trend, allowing for direct application without data transformation. When data exhibits exponential or power law relationships, logarithmic transformations can simplify the problem to linear regression, but nonlinear least squares can be applied directly to fit more complex models. Polynomial models can also utilize least squares without requiring log transformations, as they extend power law relationships. The discussion highlights the importance of model assumptions, noting that even with a linear trend in scatter plots, violations of these assumptions can lead to misleading results. Overall, nonlinear least squares provides a flexible approach for fitting various types of data relationships in regression analysis.
fog37
TL;DR Summary
understanding regression in general
Hello,
Regression analysis is about finding/estimating the coefficients for a particular function ##f## that would best fit the data. The function ##f## could be a straight line, an exponential, a power law, etc. The goal remains the same: finding the coefficients.
If the data does not show a linear trend, we cannot straight use linear regression. For example, in the case of data following an exponential trend, we can take the log of the ##Y## data (leaving the ##X## data alone) and get a straight line relation between ##log(Y)## and ##X##. At this point, we can apply least squares and get the required coefficients. That is nice hack: turn the problem into a linear regression problem to find the coefficient using logs...The same goes for a power law relation between ##Y## and ##X##...
A polynomial is simply an extension of the power law. I think we can apply least-squares to minimize the ##MSE## without any log transformation...Is that correct?
What about other more general relationships? I am looking into "nonlinear" least squares. At high level, is it a technique to find the coefficients using a variation of least-squares (I guess the ordinary least-squares which minimizes the MSE is called linear least-squares) without having to transform our data so it follows a linear trend?
thank for any clarification!
Yes.
Not sure what the power law model is.
If you have data, ##(y_i, x_i)## and you see that the curve ##Y = a X^2 + b## might fit, you can square your ##x_i## values and apply linear regression. You can extend this to polynomials. The "linear" part of linear regression indicates to how the coefficients appear in the model.
No. It works as long as the coefficients appear in the model in the appropriate way.
Thank you.
As far as linear regression goes, what happens if the scatter plot of ##Y## vs ##X## shows a good linear trend/association but the required model assumptions (residuals are not uncorrelated and have equal variance in the graph residuals vs ##X##) are not satisfied? Is that even possible? Or will we not see a linear trend in the scatterplot if the assumptions are not met?
Thanks again
fog37 said:
Thank you.
Correlated residuals sound like it is a time series. Is that what you mean?
Do you mean that the variance might be proportional to the ##Y## magnitude? That would imply a model like ##Y = \epsilon X##. I think you should try taking logarithms of both sides: ##\log Y = \log X + \epsilon_l##.
But there are a million similar things that might come up, so it is best to wait until you have a specific case and ask about that.
In general you want to difference data that exhibits power law characteristics until the series is homoskedastic (same variance). So, for example, if your rh variable is human height, you can leave it alone, but if it is wealth or market cap of a stock, use logs so the variance does not scale with the value of the rh variable
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
