What is source of base current in transistor?
In summary, the base current in a NPN transistor is made up of three components: the injection component, which is due to holes moving from base to emitter, the transport component, which is due to recombination of electrons in the base, and the displacement or charging component, which is due to the diffusion capacitance of the b-e junction. These components work together to create a high current gain in the transistor.
goodphy
216
Hello.
Let me think about the NPN transistor (Collector-Base-Emitter order). Here base-emitter voltage is forward-biased (The base is higher than the emitter in voltage.) thus current flow of majority carriers (Here they are electrons in N and holes in P) occurs from emitter to base.
In next, the collector and base is now reverse-biased. (Collector is higher than base in voltage.) This reverse bias basically prevents majority carrier flow in NP junction but allows only minority carrier flow. But here in base there is presence of large number of electrons which actually came from the emitter by forward-bias between PN junction and electron in base (P-type extrinsic semiconductor) is minority! Thus they can flow to collector. In conclusion, current flow from emitter and collector ICE is made.
Here is my question: in this logic, where is base current? what is the source of base current? I've suspected it is minority current in reverse-biased collector-base but they can be going to emitter since they see forward-bias between base to emitter!
Could you please clarity this?
The base is only lightly doped, so that a majority of the electrons that come from the emitter will be swept through into the collector to give the device a high current gain. But it is inevitable that some of the electrons will combine with holes in the base P material, and it's this flow of holes to the active base region that accounts for base current.
Read more: http://www.radartutorial.eu/21.semiconductors/hl19.en.html
Likes goodphy
Thanks. Thus..some of electrons are combining holes in base thus concentration of holes in that area becomes lower, leading diffusion of holes from base conductor to base to re-fill the holes. Is it right summary?
Actually, the base current due to recombination is only a small fraction of the total base current. When an external source forward biases the b-e junction, electrons from the emitter, and holes from the base, are acted upon by the E field so that base holes move towards emitter and emitter electrons move towards the base. Because the base is very lightly doped in comparison to the emitter, the density of holes towards emitter is much lighter than that of emitter to base.
The component of base current due to holes moving from base to emitter is called the "injection component" of base current. When a few electrons from the emitter fail to reach the collector and recombine in the base, electrons eventually exit the base lead to preserve charge neutrality. This tiny part of the base current is called the "transport component" of base current.
Also, there is yet another component of base current called "displacement" or "charging" component. The b-e junction has a diffusion capacitance. As frequency increases, more ac current is needed to charge and discharge this capacitance. At a high enough frequency, it takes as much base current to charge/discharge Cdiffusion as there is collector current. In other words, for 1.0 mA of Ic, a full 1.0 mA of Ib is needed. At this frequency, the current gain beta equals 1.0. This is called the transition frequency "ft".
Aren't you glad you asked?
Claude
Likes Shafia Zahin and goodphy
Claude
Yes, very detailed. Thanks for giving such a explanation which I ever didn't find in google.
FAQ: What is source of base current in transistor?
1. What is the source of base current in a transistor?
The source of base current in a transistor is the voltage applied to the base terminal. This voltage creates an electric field in the base region, causing electrons to flow from the emitter to the base, resulting in a base current.
2. How does the base current affect the operation of a transistor?
The base current controls the flow of current between the collector and emitter terminals in a transistor. By varying the base current, the transistor can be turned on or off, allowing it to act as a switch or an amplifier.
3. Is the base current constant in a transistor?
No, the base current is not constant in a transistor. It varies depending on the voltage applied to the base terminal and the characteristics of the transistor itself. The base current can also be affected by temperature and other external factors.
4. What happens if the base current is too low in a transistor?
If the base current is too low, the transistor may not be able to turn on fully, resulting in a lower output current. This can lead to distortion in signal amplification and may affect the overall performance of the transistor.
5. How is the base current related to the collector and emitter currents in a transistor?
The base current is directly related to the collector and emitter currents in a transistor. The collector current is typically much larger than the base current, and the emitter current is the sum of the base and collector currents. The ratio of collector current to base current is known as the current gain or beta value of the transistor.
