What is the action for E-M in terms of E & B?
  • Thread starter Thread starter Ankerbrau
    Terms
The discussion centers on the action for electromagnetism, specifically the expression F_{\mu\nu}F^{\mu \nu} and its implications when expressed in terms of electric and magnetic fields, leading to equations of motion suggesting E=0 and B=0. Participants clarify that the correct canonical variables for electrodynamics are the components of the 4-vector potential A_{\mu} and their derivatives, rather than E and B fields. It is emphasized that the Lagrangian density E^2 - B^2 is invalid due to the absence of derivatives, and the need for a valid Lagrangian in terms of E and B is questioned. The Aharonov-Bohm effect is referenced to highlight the importance of gauge-invariant quantities related to A_{\mu}. Ultimately, the consensus is that while E^2 - B^2 may seem appealing, the variational principle must incorporate the potentials A_{\mu} as canonical variables.
Ankerbrau
Typically the action for E-M is
where
F_{\mu\nu}=\partial_\mu A_\nu-\partial_\nu A_\mu
since the equations of motion for
A_{\mu}
are the inhomogenous Maxwell equations.
However, here comes my problem:
If one expresses this action in terms of the electric and magnetic
field E and B
F_{\mu\nu}F^{\mu \nu}=B^2-E^2
the equations of motion for those fields
would be
E=0
and
B=0.
So, where is the trick and what is the correct action
for the fields E and B?
Thanks in advance for your ideas and comments!
The correct canonical variables for electrodynamics are the components of 4-vector potential and their derivatives. Perhaps the best way to see this is to include the Lagrangian for a test particle, which requires coupling the momentum of the particle to the 4-vector potential. It's therefore obvious that the E and B fields cannot be canonical variables. Landau and Lifschitz, The Classical Theory of Fields, is a good reference for this.
\mathcal{L} = E^2 - B^2 is not a valid Lagrangian density, because it contains no derivatives.
Thanks, obviously
E^2-B^2 is not the right Lagrangian.
My question was more:
Is there any Lagrangian at all in terms of E and B,
no matter how awkward it looks?
Today a colleague explained me that
experimentally the Aharonov-Bohm effect showed
that the real physical can only be A_\mu,
theory wise it is connected to gauge invariant quantities
that do not depend on E and B like
\int A_\mu dx^\mu
I would say that E^2-B^2 is the right Lagrangian (density), but the variational principle must involve the potentials A_\mu as canonical variables. As I said, if you couple electrodynamics to matter, this is more obviously forced on you.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Hello, I'm joining this forum to ask two questions which have nagged me for some time. I am in no way trolling. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. Yes, I'm questioning the most elementary physics question we're given in this world. The classic elevator in motion question: A person is standing on a scale in an elevator that is in constant motion...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
