What is the Angle of Deflection in a Colliding Ball and BB Gun Problem?
  • Thread starter Thread starter mixedmetaphor
    Angle Deflection
The problem involves a rubber ball being shot by a BB gun, with the goal of determining the angle of deflection after the BB becomes embedded in the ball. The angle of deflection refers to the angle the swing makes with the vertical after the collision. To solve this, one must first calculate the velocity of the combined mass of the ball and BB using conservation of momentum. This velocity is then converted into potential energy as the ball swings upward, allowing for the calculation of the height reached. Finally, trigonometric functions can be applied to find the angle of deflection based on the height achieved.
mixedmetaphor
A 280 g rubber ball is hanging from a 27cm long swing in a booth at a carnival. A little girl shoots it with a BB gun in attempt to win a gigantic, stuffed Daffy Duck doll. The mass of each BB is 3g and the muzzle speed of the gun is 21m/s. If the BB penetrates the ball (and gets stuck inside), what is the mass angle of deflection of the ball?
p=mv (momentum), conservation of momentum, trigonometry.
I feel confident that I could solve this using some trig and momentum if I knew what the problem meant-what is an angle of deflection? If it's what I think it is (at what angle they collide) then could there be one if the two are stuck together? Or is it the angle through which the ball swings? Any ideas?
Welcome to PF.
The angle of deflection is the angle the string makes with the vertical.
Solve for the velocity of the combined bullet/ball first. Then use that velocity as the kinetic energy that gets consumed by gravity as it swings upward. KE after impact will of course equal the potential energy PE at its height.
Using that height and an appropriate trig function you should be able to solve directly for the angle.
Thanks so much, I understand now.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
