What is the angular speed in revolution per minute?
To determine the angular speed in revolutions per minute (rpm) for a new amusement park ride with a 14.2-ft diameter and a centripetal acceleration of 3g, the radius is calculated as 2.16 meters. The required centripetal acceleration translates to a velocity of 7.97 m/s. Using the relationship between linear velocity and angular speed, the angular speed is initially found to be 3.69 rad/s. However, a calculation error occurs in the conversion to rpm, leading to an incorrect final answer. The discussion emphasizes the importance of working with symbols initially to minimize errors in calculations.
jimmyboykun
You are consulting for an amusement park that wants to build a new "Rotor" ride. In order to increase capacity, they would like to build a unit with a 14.2-ft diameter. The Rotor should provide a centripetal acceleration of 3g. What must be the angular speed in revolutions per minute (rpm)?
a(centripedal)= v^2/radius
v=ωr
1ft=0.3048m---> 14.2ft*0.3048m/ft= 4.33m
4.33/2= 2.16(this is the radius)
3(9.81m/s^2)= 29.43m/s^2
v^2=2.16*29.43m/s^2=63.5688
sqrtv=sqrt63.5688=7.97m/s
v=ωr
7.97m/s=ω2.16
7.97/2.16=ω
ω=3.69rad/s
3.69rad/s*1rev/2∏*60s/1m= 344.77rpm
344.77rpm is my final answer but I got that wrong, where did I go wrong in my calculations?
It seems like you are taking the correct steps. However, I get a different numerical answer than you do.
Also, may I suggest that you don't plug all of those numbers in immediately, and just work with symbols until you have an expression for what it is you are looking for? It'll make the work easier for you, and you'll be less error prone.
It's correct up to the very last step. Then, you got the decimal point in the wrong place.
Chet
yeah I realize that. it seems that I have to convert rad/s to rpm
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
