What is the angular velocity of the merry-go-round now?
The discussion revolves around calculating the new angular velocity of a merry-go-round after four people step onto it. Initially, the merry-go-round has a diameter of 4.3 m and an angular velocity of 0.78 rad/s, with a moment of inertia of 1760 kg m^2. After the people step on, the calculated new angular velocity is 0.46 rad/s. For the second scenario, where the people jump off, the initial angular velocity should be updated to 0.46 rad/s, which affects the calculations. The confusion in the second part was clarified by recognizing the need to use the updated angular velocity from the first scenario.
AlvinC
A 4.3 m diameter merry-go-round is rotating freely with an angular velocity of 0.78 rad/s. Its total moment of inertia is 1760 kg m^2. Four people standing on the ground, each of mass 67 kg, suddenly step onto the edge of the merry-go-round.
1)What is the angular velocity of the merry-go-round now?
2)What if the people were on it initially and then jumped off in a radial direction (relative to the merry-go-round)?
I_i*w_i=I_f*w_f
w_f=(I_i/I_f)*w_i
For question 1 I plugged the numbers in and got 0.46 rad/s.
w_f=(1760/(1760+4*67*2.15^2)*.78 =0.46 rad/s
For question 2 since the people were on it initially i made I_f in my previous question to I_i and I_i to I_f. So it looked something like this:
w_f=(2998.83/1760)*.78 = 1.3 rad/s which was wrong. Not sure what I did wrong.
i also get same answer
you sure that wi in second case is .78 and not .56 like we found in second case ?
Oh yess! I forgot to make .46 as my new initial angular velocity. Much Thanks!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
