MHB What is the area of rectangle ABCD?
  • Thread starter Thread starter Albert1
    Area Rectangle
To find the area of rectangle ABCD, given points E and F on sides BC and AB respectively, and the lengths BF = CE = 4 and BE = 2, one must analyze the geometric relationships and angles formed by the intersections of lines AE and CF. The condition that angle APC equals the sum of angles AEB and CFB suggests a specific configuration that can be used to derive the rectangle's dimensions. By applying geometric principles and the properties of rectangles, the area can be calculated. The solution involves determining the lengths of sides AB and BC based on the given segments. Ultimately, the area of rectangle ABCD can be expressed as the product of its length and width derived from these calculations.
Albert1
$Rectangle\,\,ABCD\,\,given\,\, point \,\,E,F \,\,on \,\,\overline {BC},\overline {AB}\,\,\, respectively$
$if \,\,\overline{BF}=\overline{CE}=4,\overline{BE}=2,point \,\, P \,\,is\,\, the \,\, intersection\,\ of\,\,\overline{AE}\,\,and\,\,\overline{CF},\,\, and \,\, \angle APC=\angle AEB+\angle CFB$
$please\,\,find \,\, the \,\, area \,\, of \,\, rectangle \,\,ABCD$
Mathematics news on Phys.org
My attempt:
Let
\[\alpha =\angle AEB\: \: \: and \: \: \: \beta =\angle CFB\]
Note, that
\[\angle APC = \angle FPE = \alpha +\beta\]
The quadrilateral, $BFPE$, has the angle sum:
\[90^{\circ}+2( \alpha +\beta )=360^{\circ}\]
Thus, $\alpha + \beta = 135^{\circ}$
$\alpha$ and $\beta$ are easily calculated:
\[\tan\beta =\frac{\overline{BC}}{\overline{BF}}=\frac{3}{2}\Rightarrow \: \: \beta =56,31^{\circ}\]
\[\alpha = 135^{\circ}-56,31^{\circ}=78,69^{\circ}\]
Finally, $FA$ is found:
\[\tan \alpha =\frac{4+\overline{FA}}{2}\Rightarrow \overline{FA}=6.\]
Thus, the rectangle, $ABCD$, has the area: $6 \cdot 10 = 60$.
lfdahl said:
My attempt:
Let
Note, that
Your answer is correct,thanks a lot .
But how do you get the value of $tan\,\alpha$ using a calculator ? if so try not
Here it is without aforementioned device (if such a device was actually used).
Using lfdahl's diagram and the result $\alpha+\beta=135^\circ$,
$$\tan(\alpha+\beta)=-1=\frac{\tan(\alpha)+\tan(\beta)}{1-\tan(\alpha)\tan(\beta)}=\frac{\tan(\alpha) + 3/2}{1-3\tan(\alpha)/2}\implies\tan(\alpha)=5$$
and the result follows.
Without the use of a calculator:
\[\tan(\beta )=\frac{3}{2} \\\\ \tan(\alpha +\beta )= \tan(135^{\circ})=\tan(90^{\circ}+45^{\circ})=-1 \\\\ \tan(\alpha +\beta )=\frac{\tan(\alpha )+\tan(\beta )}{1-\tan(\alpha )\tan(\beta )}\Rightarrow \tan(\alpha )=5 \\\\ \tan(\alpha )=\frac{\overline{AB}}{2}\Rightarrow \overline{AB} = 10\]
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
