What is the benefit of using an electromagnet in a generator
In summary, electromagnets are used in generators because they have historically been stronger than permanent magnets. However, with advancements in technology, permanent magnets are now being incorporated into motors. The use of electromagnets allows for easier regulation of the terminal voltage, whereas the difference between power in and power out is dependent on the specific design of the generator.
Amanda H
Mentor note: Post moved from Educators and Teaching section
Hi
I would appreciate some clarity regarding using electromagnets as generators? Why are they used instead of permanent magnets specifically given that electrical power is needed? What is the difference between the power in and power out?
Thanks
Hi
Thanks
Using electromagnets in the field, it is possible to regulate the terminal voltage of the generator as per the load. We can change the field excitation to regulate the voltage.
Look up Automatic Voltage Regulator (AVR) in power system.
https://www.google.co.in/url?sa=t&source=web&rct=j&url=https://en.wikipedia.org/wiki/Voltage_regulator#Automatic_voltage_regulator&ved=0ahUKEwjy3s-lu_nRAhUaTI8KHWHtA78QygQIKzAB&usg=AFQjCNFxzUhTp5qI35OHMtxkvngBMB74XQ
Could you elaborate this part?
Electromagnets have historically been a feature of generators because their field was stronger than that of the permanent magnets available. Only in recent decades have permanent magnets become available with fields stronger than that of electromagnets, so you do find these being incorporated into motors, especially.
cnh1995's point about controlling electromagnets to achieve regulation is a good one, and possibly the advantages of both technologies could be exploited by designing a generator that employs a combination of permanent and controllable electromagnets.
Related to What is the benefit of using an electromagnet in a generator
What is the benefit of using an electromagnet in a generator?
The use of an electromagnet in a generator allows for the generation of electricity without the need for a permanent magnet. This means that the magnetic field can be turned on or off, providing greater control and flexibility in the production of electricity.
How does an electromagnet work in a generator?
An electromagnet works by converting electrical energy into magnetic energy. When an electric current flows through a wire, it creates a magnetic field around the wire. In a generator, the electromagnet is rotated within a stationary coil of wire, inducing a current in the wire due to the changing magnetic field.
What are the advantages of using an electromagnet over a permanent magnet in a generator?
One advantage of using an electromagnet over a permanent magnet in a generator is that the strength of the magnetic field can be easily controlled by adjusting the amount of current flowing through the wire. This allows for greater efficiency and precision in the production of electricity.
What are some practical applications of using an electromagnet in a generator?
Electromagnets are commonly used in generators for a variety of practical applications, such as powering electric motors, generating electricity for household appliances, and producing electricity in power plants. They are also used in a range of industries, including transportation, telecommunications, and manufacturing.
Are there any limitations to using an electromagnet in a generator?
One limitation of using an electromagnet in a generator is that it requires a constant flow of electricity to maintain the magnetic field. This means that if the power supply is interrupted, the generator will stop producing electricity. Additionally, electromagnets may also be more expensive to produce than permanent magnets, depending on the size and strength required for the specific application.
  • Electrical Engineering
