What is the Best Voltage Regulator for a Dual Polarity Power Supply?
For a dual polarity power supply providing -17V to +17V, using a "fake" ground at +17V is recommended, allowing for a regulator that can handle 0 to 35V. The LM317 can be used for positive output, while the LM337 is suitable for negative output. A Mitsubishi dual tracking regulator is also an option, and circuit diagrams are available in its datasheet. A transformer providing 30 volts center-tapped is necessary for this setup, along with a bridge rectifier for filtering. This approach effectively resolves the challenge of creating a dual polarity power supply.
elecz
I want to make a power supply which gives DC voltage from -17V to +17 volt, i.e of both polarities. Someone please tell me which voltage regulator is easiest and most appropiate to use? Thankyou!
Easiest would be to generate a "fake" ground at +17V and then find a regulator that can do 0 to 35V. What I mean by that is that you should keep the power supply isolated from ground and then connect the case ground to the +17V output of your power supply.
Search digikey.com (US) or farnell.com (Europe) for a 35V capable regulator.
An LM317 for instance would give you -15.8 to +17V connected that way. Close but not quite.
I was a bit unclear ... you will need two regulators: one adjustable 0 to 35V and one fixed or adjustable set to +17V.
Ok thankx.. But I want to know exact device name. e.g LIM117, I want to know more...
Mitsubishi have dual tracking regulators like this:
http://monopoly.highspies.com/pdf/m5230l.pdf
There are circuit diagrams in that data sheet. Note that high current outputs can be obtained by adding power transistors.
You would need a transformer that gives 30 volts centre tapped. If you ground the centre tap and use a bridge rectifier, this will give +/- 21 volts after filtering.
If you preferred to get individual regulators, you could use the LM317 for the positive output and a LM337 for the negative output.
There are lots of regulator circuits here:
http://www.hobbyprojects.com/V/voltage_regulators.html
Thanks a lot! You have solved my big problem...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
