MHB What is the change of variable for proving the fractional part integral?
The discussion focuses on proving the integral $$\int^1_0 \left \{ \frac{1}{x} \right \} \, dx = 1 - \gamma$$ using a change of variable where $\frac{1}{x} = t$. This transformation leads to the integral being rewritten as $$\int_{1}^{\infty} \frac{\{t\}}{t^{2}} \, dt$$. The proof involves evaluating this integral through a series of steps that culminate in the limit of a logarithmic expression. Ultimately, the result confirms that the integral equals $1 - \gamma$. The discussion effectively demonstrates the relationship between the integral and the Euler-Mascheroni constant, $\gamma$.
alyafey22
MHB
Prove the following
$$\int^1_0 \left \{ \frac{1}{x} \right \} \, dx = 1- \gamma $$​
Mathematics news on Phys.org
ZaidAlyafey said:
Prove the following
[sp]With the change of variable $\displaystyle \frac{1}{x}= t $ the integral becomes...
$\displaystyle \int_{0}^{1} \{\frac{1}{x}\}\ d x = \int_{1}^{\infty} \frac{\{t\}}{t^{2}}\ d t = \sum_{n=2}^{\infty} \int_{n-1}^{n} (\frac{1}{t} - \frac{n-1}{t^{2}})\ d t = \lim_{n \rightarrow \infty} (\ln n - \sum_{k=2}^{n} \frac{1}{k})= 1 - \gamma$[/sp]
Kind regards
$\chi$ $\sigma$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
