What is the charge for Hexaminotriphenylene?
The discussion centers on the potential replacement of transition metals (Cr, Mn, Fe, Co, Rh, Os, Ir) in the structure X3(HITP)2 with magnesium (Mg). Concerns about stability arise due to magnesium not being a transition metal, which may affect the structural integrity of the metal-organic frameworks (MOFs). The square planar configuration typical of HITP MOFs is not characteristic of magnesium compounds, further raising doubts about the feasibility of using Mg in this context. Overall, the consensus leans toward skepticism regarding the stability of magnesium in these structures compared to the transition metals.
deepalakshmi
I have seen the structures like X3 (HITP)2 (X = Cr, Mn, Fe, Co, Rh, Os, Ir). Can I replace X with Mg? Will it be stable?
Chemistry news on Phys.org
No idea, but one thing definitely asks for attention: what does Mg miss, that all other metals listed have?
well, all the other elements are transition elements where as Mg is not.
Yep - that makes me doubt stability. But it is just a guess.
HITP MOFs are generally formed with metals in a square planar configuration, which isn’t found in magnesium compounds.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
