What is the current perspective on quantum interpretation?
In summary: CH because, according to CH, a quantum theory of a microscopic system offers a multiplicity of consistent logics a physicist can use to reason about that system independently from any experimental apparatus interfacing with the system or its membership in an ensemble. It does so with the ordinary observables, sample spaces, and event algebras of QM or more general QFTs etc.Instrumentalism because the consistent logics mentioned above don't have to come with any realist baggage. A physicist can switch between incompatible consistent logics at their leisure if it aids in predicting measurement outcomes, without having to worry about any ontological* implications of this incompatibility.*Though I don't yet rule out realist
  • #106
The Everett interpretation. But I think the current language in which we talk about it is a little misleading.
  • #108
stevendaryl said:
Quantum mechanics violates either locality or separability in the above sense. This is shown by the EPR experiment. If Alice and Bob are in regions that are far removed from each other spatially, the evolution of the state of Alice's region depends on what happens in Bob's region.
The state evolves with a unitary transformation ##\hat{C}(t)## obeying
$$\mathrm{i} \dot{\hat{C}}=\hat{H}_1 \hat{C},$$
and the operators describing observables by one obeying
$$\mathrm{i} \dot{\hat{A}}=-\hat{H}_2 \hat{A},$$
where ##\hat{H}_1+\hat{H}_2=\hat{H}## is the Hamiltonian of the system. The split of ##\hat{H}## in two arbitrary self-adjoint operators ##\hat{H}_1## and ##\hat{H}_2## doesn't change anything in the physical predictions (probabilties for the outcome of measurements). It just defines the "picture of time evolution".
Can you specify what you mean by the last sentence? Are you referring to the partial traces, defining the states of the part of the system measured by Alice or Bob, respectively?
If yes, then of course you are right in a specific sense, and it also immediately follows that what's violated is separability and not locality (in the case of local relativistic QFTs) since the time evolution by construction (Hamilton density depends only on one space-time point and the microcausality property is fulilled for all local observables).
  • #109
The quantum state is not separable in the sense that I am talking about. You can't talk about the quantum state of a single region of space.
  • #110
vanhees71 said:
If yes, then of course you are right in a specific sense, and it also immediately follows that what's violated is separability and not locality.
I think that locality is sort of meaningless without separability. With separability + locality, physics is local, in the sense that to figure out what's going to happen in the near future, I don't need any more information than knowing what's happening nearby right now.
Likes mattt
  • #111
That's what I was asking! You said above "
(emphasis mine). Now you say yourself that this makes no sense
You are right as long as you don't specify what you mean by that, and it makes some sense, when you consider the standard example with an entangled photon pair, where A and B measure one of the two photons each, and the single-photon states are given by partial tracing the state over the other photon.
For a local relavistic QFT you have locality of the interactions (as defined above) but inseparability due to entanglement.
  • #112
stevendaryl said:
Suppose we have an anti-correlated twin pair, and Alice and Bob are each measuring particle spin along the z-axis. Let's suppose that Bob performed his measurement before Alice (but close enough that there is no possibility for light to travel from Bob to Alice before Alice performs her measurement). Then whether Alice gets spin-up depends on whether Bob got spin-up or spin-down.
Let me expand on separabilty + locality: Let ##\Delta t## be some time interval.
Suppose we divide the universe (or the patch that we are interested in) into 4 regions:
  1. Region ##A##, where Alice is performing measurements.
  2. Region ##AN##, which is the neighborhood of ##A##, the set of points that are less than ##c \Delta t## away from Region ##A##.
  3. Region ##B##, where Bob is performing measurements.
  4. Region ##BN##, which is the neighborhood of ##B##.
  5. Region ##C##, which is everything else.
Assume that regions ##A, AN, B, BN## have no overlap (but ##C## touches both ##AN## and ##BN##).
Now, we're trying to predict the state of ##A## at time ##t+\Delta t##. If the world is separable and local, then we don't need to check on the state of ##B, BN## or ##C## to make a prediction about the state of ##A##.
  • #113
Yes, and in that sense, QFT is not local.
  • #114
Are you making a distinction between prediction and expectation?
In the Qbist and similar perspectives, the local agent (Alice) does not have any other choice but to form the expectation from available information.
/Fredrik
  • #115
/Fredrik
I don't completely understand what the Qbist perspective is, but I don't think that there is any objective state of the universe in a Qbist interpretation. So it's not clear what locality means without a notion of state.
  • #116
You have to specify what you mean by local, and a local relativistic QFT is local in a specific sense (Hamilton density a polynomial of the field operators and their derviatives at one space-time point and microcausality property for all local observables) and "non-local" in the same sense as any QT, and I think it's a good solution of the problem to specify the different sense of locality used here by calling the latter type "inseparability". Einstein made very clear that his quibbles with QT refer to "inseparability" and not so much on "non-locality".
  • #117
That's what I just did: The state of the universe factors into the state of local regions, and the state of local regions evolves in a way that depends only on neighboring regions.
  • #118
Yes, there is no objective state in Qbism. Also there locality follows from the construction, since any comparasions or is made on the information at hand of the local agent . This means any "external information", such as a phone call from Bob, has to be communicated to Alice first. And this communication is treated just like any other "measurement".
Also a distinction is that in the Qbism view I think most consider the purpose of expectations, is not to determined what will happen, but to decide howto place the bets. Ie. the expectation of Alice, determines first of all Alices own action - not the backreaction of the environment.
From my perspective, what you describe are various correlations (while mixing information from different agents, without considering the communication channel), that has no "function" in a Qbist interpretation I think.
/Fredrik
  • #119
I would say, rather, that you're using a narrower meaning of "locality" than Einstein. The point of locality is Einstein's belief that all physics is local, that to understand what's going on in a small region, we need only consider that region and neighboring regions. QFT is not local in that sense.
  • #120
For an appropriate definition of "state" and "prediction", QFT meets this requirement.
You appear to be using a different definition than the "appropriate" one I just referred to; your apparent definition seems to be saying that, since knowing B's measurement result gives us additional information about the probabilities for A's measurement result, we need to "check on the state" of B in order to make a prediction about the state of A. However, by this definition, it is equally true that we need to check on the state of A in order to make a prediction about the state of B. But those two claims, combined, would put us into a never-ending circle of checking on B to check on A to check on B to check on A to...
The fundamental conflict here is really between relativistic invariance and the implicit claim of QM, on which all discussions of "nonlocality" and "nonseparability" rely, that it makes sense to assign a "state" to the whole universe as a function of "time". The real point is that, at present, nobody knows how to resolve this conflict--nobody has a theory that has both properties, relativistic invariance and a "state of the universe" as a function of time.
  • #121
No, it just means that the evolution of the global state does not "factor" into evolution of local states. Or, maybe the global state is more than the sum of all the local states.
Let me illustrate with a very simple discrete-time cellular automaton analogy
Suppose you have a cellular automaton with 4 cells labeled ##A, AN, C, BN, B##.
  • Cell ##A## has ##AN## as a neighbor.
  • Cell ##AN## has both ##A## and ##C## as neighbors.
  • Cell ##C## has both ##AN## and ##BN## as neighbors.
  • Cell ##BN## has both ##C## and ##B## as neighbors.
  • Cell ##B## has only ##BN## as a neighbor.
Let ##V## be the set of possible states of any cell. A state of the whole automaton is a 5-tuple of values ##a, an, c, bn, b##, each value an element of ##V##. If ##s## is a state of the whole automaton, then I will use ##s[a]## to mean the state of cell ##A##, ##s[an]## is the state of cell ##AN##, etc.
Then there is a transition relation ##T(s, s')## that describes the evolution of the cellular automaton. The meaning is that if the global state at time ##t## is ##s##, then ##s'## is a possible global state at time ##t+1##. (We could make this model more sophisticated by using probabilities, instead of possibilities, but this is just a toy model for the purpose of illustrating the concept of separability.)
We say that the transition relation ##T## obeys locality if it factors into 5 local transition relations
  1. ##T_1(a, an, a', an')## governing cell ##A##
  2. ##T_2(a, an, c, a', an', c')## governing cell ##AN##
  3. ##T_3(an, c, bn, an', c', bn')## governing cell ##C##
  4. ##T_4(c, bn, b, c', bn', b')## governing cell ##BN##
  5. ##T_5(bn, b, bn', b')## governing cell ##B##.
##T## factors into these local transition relations in case
##T(s,s') \Leftrightarrow ##
##T_1(s[a], s[an], s'[a], s'[an]) \wedge ##
##T_2(s[a], s[an], s[c], s'[a], s'[an], s'[c]) \wedge ##
##T_3(s[an], s[c], s[bn], s'[an], s'[c], s'[bn]) \wedge ##
##T_4(s[c], s[bn], s[ b], s'[c], s'[bn], s'[ b]) \wedge##
##T_5(s[bn], s[ b], s'[bn], s'[ b]) ##
With Alice and Bob both measuring spins along the z-axis, the global transition relation does not factor into local transition relations.
  • #122
StevieTNZ said:
I trust in the consciousness causes 'collapse' (regardless if its physical or not) interpretation.
This is not an interpretation.
  • #123
This only makes sense if there is a "global state". It is not clear that there is one consistent with relativistic invariance.
This is not a valid analogy because the corresponding things in the QM case are regions of spacetime. Regions of spacetime don't "update" from one "time" to the "next". They just are. And the "neighbor" connections between them are one-way causal relations, not two-way "neighbor" relations.
  • #124
Relativistic invariance doesn't prevent there from being a global state. The state would be frame-dependent, but I don't think that's a problem.
I think the analogy is very close. As I said earlier: Pick a "patch" of spacetime for which we can set up an inertial cartesian coordinate system ##(x,y,z,t)##. You split space up into boxes with dimensions ##\Delta x, \Delta y, \Delta z##. The state of one box at time ##t+\Delta t## depends on the state of that box and neighboring boxes at time ##t## (where "neighboring" means that some points in the neighboring box is less than or equal to ##c \Delta t##).
  • #125
For example, in flat spacetime, the classical (relativistic, but non-quantum) global state at time ##t## according to a Cartesian coordinate system ##(x,y,z,t)## would be provided by giving the values of ##\vec{E}## and ##\vec{B}## at each point ##(x,y,z)## at time ##t##, and the positions and locations of each particle at time ##t##.
  • #126
I don't see how it wouldn't be a problem, since "frame-dependent" is inconsistent with "relativistically invariant".
This state is, as you say, frame-dependent, and therefore not relativistically invariant. So I am totally confused as to how you can say this isn't a problem for consistency with relativistic invariance.
Likes vanhees71
  • #127
Again, this is not a valid analogy because your ##A##, ##AN##, ##C##, ##BN##, ##B## are not "boxes" in space, they are regions of spacetime. It makes no sense to talk about "updating the state" of a region of spacetime from one time to the next.
  • #128
I'm sorry if I gave the wrong impression. The cells correspond to regions in SPACE, not regions in SPACETIME.
  • #129
Why does it matter if the notion of "state" is relativistically invariant, or not?
As I said, we can pick an inertial cartesian coordinate system, and with respect to this coordinate system, we can (pre-quantum mechanics) define the "state of the universe (or the patch of interest)" at time ##t## by giving the values of the electric and magnetic fields at every point in space, and by giving the locations and positions of every particle.
For my purposes, I don't care about relativistic invariance. The point is simply that the "state" of any small region of space at time ##t + \Delta t## depends only the state of neighboring regions at time ##t## (where "neighboring" means the distance is less than ##c \Delta t##).
Relativistic invariance doesn't prevent me from doing this. It says, instead, that it's true for ANY choice of an inertial cartesian coordinate system.
  • #130
Ah, I see.
Because if your theory, or interpretation, or whatever, isn't consistent with relativistic invariance, it can't be fundamental, and I thought the whole point of QM interpretations was to try to come up with a fundamental account of what is going on. And a fundamental account of what is going on that uses a concept of "state" where "state" is frame-dependent doesn't seem to me to be consistent with relativistic invariance.
The notion of "state of any small region of space at some particular time" is relativistically invariant--strictly speaking "small region" should be "point", but nobody is that strict when actually using relativity. I have no problem with considering, say, A's measurement of the spin of their qubit to be an "event" in the relativistic sense even though it occupies a finite region of spacetime, not a point.
I thought you were making use of a global concept of "state", where we have to assign a "state" to the whole universe at some time. That's not relativistically invariant. But it doesn't seem like you actually need that notion of "state". Your "states" are really just "events" in spacetime (where "event" has the non-strict interpretation described in my previous paragraph), and you are simply saying that some states don't depend only on other states in their past light cones. This is a purely local notion of "state", not a global one, and all of the relationships involved can be described as invariant spacetime relationships between local "states".
  • #131
Having said this, I now have a different issue to raise, with the word "depends". In Bell's Theorem, "depends" means statistical dependence--there is no way to factorize the function that describes the statistical correlation between the A and B measurement results. But then:
This seems to be using a different notion of "dependence", one in which understanding the A and B measurement results requires knowing about things that aren't in the past light cones of those measurements. Or perhaps you have some sort of notion of "causal dependence" in mind.
Also, what, exactly, is supposed to "depend" on states not in the past light cone? It can't be just the A and B measurement results by themselves; the probabilities for each of those are dependent only on states in their past light cones. Only the statistical correlation between them can't be factorized, as above.
Perhaps the correlations between the results are what leads you to require some global notion of "state"; but then it makes no sense to talk about the "state" of either A or B by themselves; only their joint state is meaningful. That notion of "joint state" is not relativistically invariant, but it's also not the state of any individual "cell" in your scenario, so again the analogy with a cellular automaton breaks down.
  • #132
I think I answered this already. Given an inertial coordinate system, there is a notion of global state that changes with time. If the laws of physics are "separable" in the sense that I'm talking about, then the laws for the evolution of the global state factors into laws for how each small region evolves. If it's not separable, then it means that the laws governing the evolution of the local states are not sufficient to determine the evolution of the global state.
An extremely simplified example might be this: Suppose there is a pair of coins, and no matter how far apart the coins are from each other, it's always the case that the ##n^{th}## flip of one coin produces the opposite result from the ##n^{th}## flip of the other coin. This is a nonlocal law of physics. A local law governing the coin would specify how the result of a coin flip depends on conditions near that coin.
Now, unlike EPR, there is a "hidden variables" explanation for this apparently nonlocal law. If somehow the coin has a "program" telling it what result to give on the ##n^{th}## flip, then that would account for the nonlocal correlation. So an apparently nonlocal evolution law can be explained in terms of a local hidden variable theory. EPR correlations, in contrast, provably cannot be explained in terms of the type of separable laws that I'm talking about.
  • #133
If the laws of physics are relativistically invariant, then there can't be any such "laws for evolution of the global state", since the global state is not relativistically invariant.
This is the same problem that I said in post #120 that nobody knows how to solve, and if nobody knows how to solve it, you can't just help yourself to assumptions and models that require that it be solved. Unless you know how to solve it and can point us to a reference that contains the solution?
  • #134
That is not true. I gave you a counterexample. If we define the "global state" to be the values of ##\vec{E}## and ##\vec{B}## at every point in space, together with the locations and positions of all particles, then classical relativistic theory gives you the evolution law for such a global state. So I don't know what you're talking about.
  • #135
The evolution law you refer to, Maxwell's Equations, is not global, it's local. The evolution of ##\vec{E}## and ##\vec{B}## at any particular point in space depends only on the values of ##\vec{E}## and ##\vec{B}##, their derivatives, and the source (charge-current density) at that point in space. So calling this an evolution law for "the global state" is meaningless as physics; you might consider it a useful choice of words, but I don't, I think it just obfuscates things.
  • #136
Yes. That's exactly my point! Classical electrodynamics is local in the sense that I'm talking about. You can define a global state, and you can define how the global state at one time depends on the global state at previous times. But, classical electrodynamics is local. The evolution of the global state factors into evolution equations in which the evolution of the local state only depends on nearby conditions.
  • #137
I see what you are saying, and I don't think we disagree on the physics. I just don't think this way of describing it in ordinary language is useful; I think it's likely to cause more confusion than it solves.
  • #138
The whole point is to say the sense in which classical electrodynamics is a local theory, but QM with entangled particles is NOT.
  • #139
Some people say that we should interpret "local" to mean the impossibility of FTL communication. I don't think that captures the notion of "local" very well. I gave the counter-example of a hypothetical pair of coins such that the ##n^{th}## flip of one coin always returns the opposite result of the ##n^{th}## flip of the other coin, no matter how far away they are from each other (but are otherwise random--there is no way to predict which will be "heads" and which will be "tails"). Such a pair of coins could not be used for FTL communication, but such a correlation is certainly non-local, intuitively.
  • #140
That's easy: a local theory can't make predictions that violate the Bell inequalities. Classical electrodynamics is local in this sense; QM is not.
But of course this definition of locality does not distinguish classical electrodynamics from QM. So it's not the one you're looking for.
Likes vanhees71
78K
18K
11K
