What is the difference between above and below the horizontal?
The discussion clarifies the distinction between angles measured above and below the horizontal in projectile motion. When an object is thrown at an angle above the horizontal, such as 35 degrees, it has a positive vertical component, while an angle below the horizontal indicates a negative vertical component. In the given example, the apple core is thrown at 35 degrees above the horizontal, meaning the angle is indeed 35 degrees, not 55 degrees. Angles are always measured from the horizontal line, with horizontal motion being zero degrees. Understanding these concepts is essential for solving related physics problems accurately.
kitkat87
Some of the questions in my homework list the velocity either above or below the horizontal. I am confused as to what the difference is.
This is the question:
"A child sitting in a tree throws his apple core from where he is perched (4.0 m high) with a with a velocity of 5.0 m/s [35 DEG above the horizontal], and it hits the ground right next to his friend.
Does that mean it's a 35 DEG angle or does it mean its a 55 DEG angle?
Imagine a horizontal line is drawn from the child extending outward.
As the child throws the apple core at an angle above the horizontal, there is a vertical component of the velocity which is positive upward.
If the core is thrown at an angle below the horizontal, the vertical component of the velocity is negative downward toward the ground.
Angles are measured using the horizontal line as the reference, so something which is thrown horizontally has an angle of zero degrees.
Thank you for clarifying :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
