B What is the difference between N = Q/nF and m = Z*I*t in electrolysis?
The discussion clarifies the use of two equations in electrolysis: N = Q/nF and m = Z*I*t. N represents the moles of hydrogen produced, with Q as charge, n as the stoichiometric number of electrons, and F as the Faraday constant. The second equation relates mass (m) to the electrochemical equivalent (Z), current (I), and time (t). It is established that to calculate hydrogen production, the equation It/(2F) is appropriate, as two moles of electrons yield one mole of hydrogen gas. The participants confirm that the factor of 2 in the equation accounts for the stoichiometry of the reaction.
Shan43
TL;DR Summary
Both of these equations seem to be revolving around Faraday's first law of electrolysis but would they be equal in the sense of what they are solving for?
N is equal to the number of moles of the electrolyzed species (in this case I am trying to find the amount of hydrogen produced) , Q is charge, n is stoichiometric number of electrons consumed in the electrode reaction (please explain what this means, and F is the Faraday constant. For the second equation, m is the mass of the substance undergoing electrolysis, Z is the electrochemical equivalent of the substance (also please explain what this is), I is current and t is time, I'm assuming in seconds. In other words, which of these equations would be the best when trying to find the amount of hydrogen produced during water electrolysis?
##n## is just the number of electrons transferred in the electrode reaction equation (as written). For example, oxidation at the anode for water-electrolysis would have a half-reaction ##\mathrm{4OH^{-}} \longrightarrow \mathrm{2H_2 O} + \mathrm{O_2} + \mathrm{4e^{-}}## and ##n=4##. A single mole of electrons has a charge of ##F##, so ##N## moles of the reaction as written ("##N \ \mathrm{mol \ rxn}##") results in a charge transfer of ##N\cdot nF##.
Meanwhile, the electrochemical equivalent ##Z## is pretty much defined as the ratio of the mass of some species used/evolved in the reaction to the charge transferred through the circuit, ##Z \equiv m/Q##.
Thank you for your clarification between the two variables. But which equation would be used to find the amount of hydrogen that will be produced from the electrolyzer? (This is not a homework question, more of a research question)
Well, at the cathode ##2\mathrm{H^+} + \mathrm{2e^-} \longrightarrow \mathrm{H_2}##, i.e. ##2## moles of electrons liberates ##1## mole of ##\mathrm{H_2}## gas. If a current ##I## flows for a time ##t##, then the charge through either electrode is ##It## and the number of moles of electrons transferred is ##It/F##. Therefore you have ##It/(2F)## moles of ##\mathrm{H_2}##.
Wow, thank you for the clear and concise explanation of faraday's law! But, just to be sure, the F is multiplied by the 2 because it takes 2 moles of electrons to produce one mole of H2 gas correct?
Likes ergospherical
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
