What is the difference between the two sine rules for resultant vector?
The discussion clarifies that there are two forms of the sine rule used for determining the direction of a resultant vector: one for sides and one for angles. Both formulas yield equivalent results, allowing them to be used interchangeably. The equivalence arises from the mathematical principle that taking reciprocals of equal fractions maintains equality. Additionally, the conversation notes that while the law of sines and the law of cosines are commonly applied, there are also less frequently used laws of tangents and cotangents. Understanding these rules is essential for solving problems related to lengths and angles in scalene triangles.
eben
Hello can anyone help me with this:
there are two sine rules for finding the direction of a resultant vector;one for the sides and one for the angle;
I tested both formulas and they all worked well and gave me equal answers, does that mean I can use them interchangeably,the rules are:
a/sinA = b/sinB=c/sinC(for finding the sides) and
sinA/a=sinB/b=sinC/c(for finding the angles)
Mathematics news on Phys.org
There is only one rule. The second one you wrote is just what you get when you take the reciprocals of all the items. Naturally if a=b and neither a nor b is zero then it will also be true that 1/a = 1/b. Whenever you perform the same operation on both sides of the equation, the equality still holds, as long as the operation hasn't produced an error (eg divide by zero)
So yes, you can use either of the two versions that you wrote above.
Likes Gavran and PeroK
thanks very much,God bless you.
One way to prove its true:
##x=y## with neither x nor y equal to 0
mpy both sides by ##1/x##: . . . . . . . . ##1 = y/x##
mpy both sides by ##1/y##: . . . . . . . . ##1/y = 1/x##
Hence: ## 1/x = 1/y##
There are four rules and they are the law of sines, the law of cosines, the law of tangents and the law of cotangents. The law of sines and the law of cosines are more common than the law of tangents and the law of cotangents.
The law of sines and the law of cosines can be used for finding a resultant vector or more commonly for finding lengths and angles in scalene triangles and there is a difference between the law of sines and the law of cosines.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
