What is the difference between Var(X) and Cov(X,X)?
  • Thread starter Thread starter Rasalhague
Variance, denoted as Var(X), and covariance, Cov(X,X), are mathematically equivalent, as Cov(X,X) is defined as the expected value of the squared deviation from the mean, which aligns with the definition of variance. The discussion highlights a misunderstanding in calculating covariance, emphasizing the need to apply the expectation operator correctly. It clarifies that Cov(X,X) can also be expressed as E[X^2] - E[X]^2, reinforcing its equivalence to variance. The conversation touches on different definitions of covariance in various mathematical contexts, indicating potential confusion in terminology and application. Ultimately, the thread seeks to clarify these concepts and their interrelations in probability theory.
Rasalhague
Var(X) = Cov(X,X) ??
Var(X)=\sum_{i=1}^N P(X_i)(X_i-EX)^2.
Cov(X,Y) = \sum_{i=1}^N\sum_{j=1}^M P(X_i,Y_j)(X_i - EX)(Y_j - EY).
If, for instance, P(X_i) = 1/N and X = Y = (1,2,3), then
Var(X) = \frac{1}{3} ((1-2)^2 + (2-2)^2 + (3-2)^2) = \frac{2}{3},
but
Cov(X,X) = \sum_{i=1}^3 \sum_{j=1}^3 \frac{1}{9} (X_i - EX)(X_j - EX)
=\frac{1}{9}((1-2)^2+(3-2)^2+2(1-2)(3-2)) = 2 - 2 = 0??
There are 9 values of (X,Y); each occurs with equal probability. I've omitted the terms that contain (2-2) from the summation. Apparently I've misunderstood something about the definition of covariance, but what?
This formula is wrong.
Here is how you calculate it. By definition, the covariance is
Cov(X,X)=E[ (X-EX)(X-EX) ]
So define the random variable Z=(X-EX)(X-EX)=(X-2)^2. The covariance is EZ. Now, if X takes on the values 1,2 and 3. Then Z takes on the values 0,1. Furthermore P\{Z=0\}=P\{X=2\}=1/3 and P\{Z=1\}=P(\{X=1\}\cup \{X=3\}) = 2/3.
Thus
Cov(X,X)=EZ = \sum_{k=0}^1 k P\{Z=k\} = 2/3
Hey Rasalhague.
I don't know what you did, but Ill use the expanded form of covariance in your definition.
Cov(X,X)
= E[(X - E[X])(X - E[X])]
= E[X^2] - E[X]^2.
You are not applying the expectation operator correctly since you are need to apply the definition of the expectation to the whole definition (i.e (X-E[X])(X-E[X) and this means taking into account shifts by the mean.
If you expand the Covariance operator you get:
Cov(X,Y) = E[XY] - E[X]E[Y] and this is done using some simple algebra which leaves us with
Cov(X,X) = E[X^2] - E[X]^2 which is the same as the variance.
You are not calculating the variance or covariance but something that I have absolutely no idea with.
The formula defines covariance for discrete variables in Simon & Blume (1994): Mathematics for Economists, end of section A5.4, and in Robert J. Serfling's online intro 'Covariance and Correlation', formula (1) which he identifies with E[(X-EX)(Y-EY)P(X,Y)] in the formula which follows that. Serfling also states that P(X,Y) means
P_X(X)\cdot P_Y(Y)
which in my example makes P(X,X) = (1/3)(1/3) = 1/9. Perhaps you could explain how you would calculate an example where X \neq Y, e.g. X = (1, 2, 3) and Y = (1, 4, 9).
I'm not sure how to reconcile Serfling's formula (1) with the way Wolfram Mathworld writes it out explicitly for the case where N = M:
http://mathworld.wolfram.com/Covariance.html
Are there two somewhat different concepts each called covariance, each corresponding to its own way of defining the mean of the product of two random variables?
Ah, reading further on that Mathworld article, it seems one definition concerns real-valued random variables from a finite sample space, another definition concerns tuples of such random variables. But still, there appear to be a variety of concepts here to which the name covariance is attached, with disagreement over certain points, and Mathworld doesn't give an explicit version of the more general definition.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
