What is the Direction of x Using the Right Hand Rule?
The discussion revolves around determining the direction of x using the right hand rule, given that z is east and y is south. The initial confusion arises from the incorrect assumption that x could also be south, which is already defined by y. After clarification, it is established that x corresponds to the upward direction. The correct application of the right hand rule confirms that x is indeed up. This conclusion resolves the initial uncertainty regarding the orientation of x.
Tiven white
If z = east and y = south, then x = ______?
Select one:
a. east
b. up
c. south
d. north
e. down
using the right hand rule the answer i got is south is this correct?
that can't be right because y is already south
you know z=east so that -z=west and y=south so that -y=north so what else is left for x?
really sorry i meant up is that correct?
Yes. Rotating y into z gives x for your thumb.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
