What Is the Distance Between the Slits in Young's Double-Slit Experiment?
In Young's double-slit experiment, the distance between the slits is calculated using the formula d sin θ = n λ, where λ is the wavelength of light (632.8 nm) and θ is the angle to the second side maximum (0.45 degrees). The calculation yields a distance d of approximately 1487.36 nm, assuming n is 2 for the second maximum. A correction is noted regarding the angle, clarifying that 0.45 degrees is not equivalent to 45 degrees. The discussion confirms the calculation method but highlights the importance of accurate angle interpretation. Accurate values are crucial for reliable results in such experiments.
Aoiumi
When two parallel slits are illuminated with monochromatic light of wavelength 632.8 nm, the angle between the center of the central maximum and the center of the second side maximum is .45 degrees. What is the distance between the parallel slits.
d sin θ = n λ
d=2(632.8 nm)/sin 45 degrees
d = 1487.36 nm
My "d" value seems a bit odd, so I wanted to make sure I did this correctly. Note that I assigned "2" as the value of n because the problem said "second side maximum". Thank you.
.45 degrees and 45 degrees are not the same thing. Apart from that (and the resulting wrong value for d), it looks fine.
Likes 1 person
Okay. Thank you for the confirmation!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
