MHB What is the distance of closest approach
  • Thread starter Thread starter Another1
    Approach
Another1
from problem I find \[ r = r_0 + At \] \[ x_0 = 3 + 2t\] \[ y_0 = -1 - 2t\] \[ z_0 = 1 + t\] and \[ A = (2,-2,1)\]
but i don't understand What is the distance of closest approach?
someone tell me to a formula please.
If $P$ is a point in space, and $L$ is the line $r(t) = \vec{r_0} + \vec{A} t$ , then
$d(P,L) = \dfrac{|\vec{Pr_0} \times \vec{A} |}{|\vec{A}|}$
you haven't actually written the path in the form r= r0+ At. It is, of course, r= <3, -1, 1>+ <2, -2, 1>t.
It is the shortest possible distance from a point, (x(t), y(t), z(r)), on the graph to the origin, (0, 0, 0). The "formula" you want is the distance formula. The distance from (x, y, z) to the origin is $\sqrt{x^2+ y^2+ z^2}$. "Minimizing" that distance is the same as minimizing the square- $x^2+ y^2+ z^2= (3+ 2t)^2+ (-1- 2t)^2+ (1+ t)^2= 9+ 12t+ 4t^2+ 1+ 4t+ 4t^2+ 1+ 2t+ t^2= 11+ 18t+ 10t^2$. You can minimize that by setting the derivative equal to 0 or by "completing the square".
To complete the square, $10t^2+ 18t+ 11= 10(t^2+ 1.8t)+ 11= 10(t^2+ 1.8t+ 0.81- 0.81)+ 11= 10(t+ .9)^2- 8.1+ 11= 10(t+ .9)^2+ 2.9. Since a square is never negative, that is smallest when t= -0.9 where its value is 2.9.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
