What is the distance of the third charge?
  • Thread starter Thread starter haengbon
    Charge
The discussion revolves around a physics problem involving three point charges: 3.0 µC, -5.0 µC, and 0 µC. The main question is determining the distance from the second charge to the third, given that the distance between the first two charges is 40m. Participants express confusion about the nature of the third charge, questioning whether it is neutral and if the system can be in equilibrium. It is suggested that if the third charge is neutral, the first two charges would attract each other, leading to a collision. The conversation emphasizes the need for clarity in the problem to find a solution.
haengbon
Three point charges, 3.0 \muc, -5.0\muc and 0 \muc.
If the distance from point 1 (3.0) and point 2 (-5.0) is 40m, what is the distance from point 2 to point 3?
coulombs law
[b
I don't know how to start this :(
The problem is not clear. Whether the third body is neutral?
Are they in equilibrium?
I'm not really sure since I only remembered this problem by memory :( but if the third body WAS neutral and they ARE in equilibrium, how would you answer this? :D
If the third body WAS neutral and they cannot be in equilibrium
um, if that's so, is it then possible to be solved?
I need to use this formula :D ?
Fe = \frac{ Kq1q2 }{ r2 }
No. Just think about it. If the third body is neutral, the other two would attract each other, accelerate towards each other, and eventually collide.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
