MHB What is the domain for variables with cube roots?
  • Thread starter Thread starter mathdad
    Domain
The domain for the expression ax + b is all real numbers (R), as there are no restrictions on x. For the expression ax^(1/3) + b, the cube root function allows for any real number, meaning the domain is also all real numbers. Negative values of x can have real cube roots, as demonstrated by the example of (-8)^(1/3) equaling -2. Therefore, the correct domain for both expressions is R, encompassing all real numbers. The discussion clarifies that cube roots do not impose restrictions on the variable x.
mathdad
Specify the domain of each variable.
1. ax + b
Here x can be any integer.
In that case the domain is R, where R is ALL REAL NUMBERS.
2. ax^(1/3) + b
Let x^(1/3) be the cube root of x.
Let D = domain
x^(1/3) is > or = 0
[x^(1/3)]^3 > or = 0^(1/3)
x > or = 0
D = {x| x > or = 0}
Is any of this right?
Mathematics news on Phys.org
1. ax + b
Correct, there would be no restriction we would need to impose on $x$.
RTCNTC said:
2. ax^(1/3) + b
Let D = domain
x^(1/3) is > or = 0
x > or = 0
D = {x| x > or = 0}
Let's think about this...what is the cube of a negative number?
Negative numbers can't have real number square roots, but negative numbers can have real number cube roots.
Sample: (-8)^(1/3) = -2
Back to my question.
(x)^(1/3) is the cube root of x. The domain can be any real number.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
