What is the Effect of Floating MOSFET Base Plate?
Leaving a MOSFET base plate floating can lead to potential issues such as voltage breakdown and electrostatic discharge (ESD) risks, as the substrate is typically connected to the source terminal for safety and isolation. The voltage acquired by a floating base plate depends on the specific device and its application, making it crucial to consider circuit design. It is common for the base plate to be connected to the drain, which complicates the notion of it being truly floating. To assess the implications of a floating base plate, detailed information like a schematic and part number is necessary. Understanding these factors is essential for ensuring circuit reliability and performance.
EE4me
TL;DR Summary
Are there any downsides to leaving a MOSFET base plate floating?
My specific system will benefit from having the MOSFET base plate floating. Are there any downsides to leaving a MOSFET base plate floating? Are there any reasons not to?
Base plate ? = body ? substrate ?
It is usual to connect the substrate to the source terminal so as to prevent voltage breakdown, ESD, and to maintain isolation by reverse biasing the PN contact layer on the substrate.
What voltage will it acquire if it is left to float ?
https://en.wikipedia.org/wiki/MOSFET#Body_effect
This depends on the specific device and the circuit/application. Usually the "base plate" is connected to the drain, so it won't be truly floating. You won't get a useful answer from us without providing more information. You could start with a schematic, the part number of the MOSFET, and a description of what you want your circuit to do.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
