What is the Effect of Reduced Air Resistance on an Object's Acceleration?
  • Thread starter Thread starter Dberry
    Force
Reducing air resistance on an object moving at constant velocity affects its acceleration by altering the net force. Initially, the net force is zero, indicating no acceleration; however, when air resistance decreases by a factor of four, the net force becomes 3/4 F. This change leads to a corresponding acceleration, calculated using F=ma. The discussion emphasizes the importance of understanding the forces acting on the object, specifically the balance between the propelling force and air resistance. Ultimately, the net force's increase due to reduced air resistance results in a measurable acceleration.
Dberry
If F is the force of air resistance on an object with mass m moving at a constant velocity, which of the following best describes the acceleration of the object when the force of air resistance is reduced by a factor of 4?
F=ma
The options listed are:
a) F/m
b) 1/2 F/m
c) 1/4 F/m
d) 3/4 F/m
My original thinking was that if there is constant velocity then there is no acceleration. But since that wasn't a choice I went with option c). However, the back of my book lists option d) as the answer, saying that the force propelling the projectile also has a force, so when the air resistance is reduced by a factor of 4 the net force must be F - 1/4 F = 3/4 F. I guess what I don't understand is why I have to subtract from the force projecting the projectile.
Thanks for your help!
To find the acceleration, you need the net force on the object. What two forces act on the object? When the object has constant velocity, what must the net force be? But when the air resistance force changes, so does the net force.
The forces acting on the object are air resistance and the force propelling it.
The net force must be zero because constant velocity means there is no acceleration, so according to F=ma F is zero.
The net force acting on the object right now are the two forces mentioned above and nothing else right? Or are the mass and velocity a part of the net force?
Right. And presumably the force propelling it does not change.
Exactly. So that tells you how big the propelling force is. (In terms of F, at least.)
Right. The vector sum of those two forces.
No.
To illustrate the problem I've created the following figures:
Before:
[URL]http://img63.imageshack.us/i/qbefore.png/[/URL]
In case image doesn't show (link): http://img63.imageshack.us/i/qbefore.png/
After:
[URL]http://img252.imageshack.us/i/qafter.png/[/URL]
In case image doesn't show (link): http://img252.imageshack.us/i/qafter.png/
As you see, the net force F_{net} increases as air resistance decreases.
Something wrong with the latex subscript..
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
