What is the elastic modulus of the wire?
To calculate the elastic modulus of a wire with a diameter of 0.2mm that stretches by 0.20% under a 6.28-N force, the correct formula is Elastic Modulus = (F/A) / (ΔL/L). The area should be calculated using A = πr², where r is 0.1mm or 1x10^-4m. The correct value for ΔL/L is 0.002, not 0.2. The initial calculation mistakenly included an extra factor of two, leading to an incorrect modulus value of 5x10^9 N/m² instead of the correct 1.0x10^11 N/m². Understanding the proper application of the formula and calculations is crucial for finding the elastic modulus accurately.
joseg707
A wire of diameter 0.2mm stretches by 0.20% when a 6.28-N force is applied. What is the elastic modulus of the wire?
Elastic Modulus=F/A/L/\DeltaL
r=.1mm=1x10-4m
6.28N/(2\pi1x10-8/.02=5x109N/m2
The right answer is 1.0x1011.
What am I doing wrong?
That should be (F/A)/(ΔL/L).
Oh, yeah. Well how do I calculate that? I know that the change is .2% if I use .002 or .2 as a value for \DeltaL/L I don't get the right answer. What is wrong with my calculation?
Area = pi*r². Looks like you have an extra factor of two in there. And ΔL/L = 0.002.
Ah! Thank you so much! I don't know why I was thinking are was 2*pi*r^2. Thanks a lot!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
