What Is the Escape Speed from the Sun to Mercury at 25 Million Kilometers?
  • Thread starter Thread starter Mecia22
    Gravity Radius
The discussion focuses on calculating the escape speed from the Sun to Mercury when a spaceship is positioned 25 million kilometers away from the Sun. The relevant equation involves gravitational force and kinetic energy, specifically Gm1m2/radius plus the distance from the Sun. It is clarified that escape speed is typically defined from a gravitating body to infinity, rather than to another celestial body. The participants confirm that the equation provided is appropriate for calculating escape speed from the Sun alone. Understanding these principles is essential for solving the problem accurately.
Mecia22
I need to what the escape speed from the sun to mercury would be if the spaceship is 25 mil km away from the sun.
Basically, all need to know is if I can do this:
Gm1m2/radius of sun+ 25 mil km away from sun=1/2 mv^2.
Also, as you get farther away you can decrease your speed. Correct?
What is "escape speed from the Sun to Mercury"? The escape speed is usually defined from some location near a gravitating body to infinity, not to another body.
Oh sorry, I meant just from the sun.
Then your equation is correct.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
