MHB What is the Factorial Expression for (ax + b)^(-1/2) - [sqrt{ax + b}]/b?
  • Thread starter Thread starter mathdad
    Expression
The discussion focuses on simplifying the expression (ax + b)^(-1/2) - [sqrt{ax + b}]/b using rational exponents. The initial approach involves rewriting the expression with rational exponents and factoring out terms with smaller exponents. A participant mentions using b^0 as a placeholder to facilitate factoring, highlighting that this technique is a matter of personal preference. The conversation emphasizes that different methods of simplification can vary based on individual style. Overall, the thread illustrates the complexities of factoring and simplifying algebraic expressions.
mathdad
Factor
This one is tricky. Can someone get me started?
Mathematics news on Phys.org
I would begin by using rational exponents in place of the radical notation:
$$(ax+b)^{-\frac{1}{2}}-\frac{\sqrt{ax+b}}{b}=b^0(ax+b)^{-\frac{1}{2}}-b^{-1}(ax+b)^{\frac{1}{2}}$$
Next, continue, using the technique I explained in your other recent threads...you now have two factors in each expression in the given difference, so begin by factoring out those with the smaller exponents. :D
Where did b^0 come from?
That's just a placeholder to make factoring a little easier...once you get more practice you won't need it. Also, it's part of how I choose to factor, and not absolutely necessary. For example, if I have the expression:
$$a+\frac{a}{b}$$
Then I would choose to factor as:
$$\frac{a}{b}(b+1)$$
rather than:
$$a\left(1+\frac{1}{b}\right)$$
Much of simplifying expressions can simply be personal preference. :D
I will work on this later..
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
